2 Pages V   1 2 >
> Tortoise-style point motors.
Vulcan
post 25 Oct 2008, 10:30
Fireman
Hello all,
I'm currently still in the planning stages with my new N gauge layout. I'm looking at which point motors to use this time around and have come across Tortoise motors. Has anyone used these with N gauge, specifically with Peco code 55?
Looking at them, they seem to be pretty enormous. I'm concerned that if they were say, mounted on a scissor crossing in N gauge, there might not actual be sufficient room to get the motors mounted next to each other. Also, I only have a baseboard depth of 5-6cm including the frame - the Tortoises will be hanging out of the bottom of the baseboard won't they? That could make placing the trestles I use to support the layout quite tricky.
I'm planning on having some 22 motors spread over the scenic section of the layout - at around £12 a pop I need to know everything is going to fit and work! Is there an alternative to the tortoise that's more appropriate to N gauge?
Thanks!
Formerly N Gauge James - but actually called Dan
Layout Progress Thread: Clifton Depot
upnick
post 25 Oct 2008, 12:42
Minister of Transport
Group Icon
Group: Plus+
Tortoise motors are more protypical in operation but with 22 points to operate on two counts you would be better with either peco motors or seep ones, both being far more economical,
They will fit far neater under the board as well.
UPNICK.
Now if you'll excuse me, I'm a busy man. I have a railroad to build.
''Building America''
Lancashire Fusil...
post 25 Oct 2008, 14:26
Paul Hamilton aka "Lancashire Fusilier"
I beg to differ with the previous advice. a) you can use remote actuation on a tortoise in case things are getting alittle congested and cool.gif purchase them in at least 6 or 12 at a time ex US (good UK to the US$) at the moment and they are an exact match for a peco or seep with accessory switch or under board mounting part too. Trust me, I am decidely tight when it comes to multiple purchases however I have proven it! Besides, I would pay a quid or two not to see my points snap over with a loud Thwack anyway!
Robert Stokes
post 25 Oct 2008, 16:01
Post #4
Station Master
Group Icon
Group: Plus+
There are alternatives to the Tortoise motors that work in the same way, i.e. slow action, but are smaller or cheaper or both. The fulgurex (which I have not used) are much smaller and a little cheaper than Tortoise. The Conrad point motor from Germany is much smaller and a lot cheaper (about £5 or less depending on exchange rate). I have used these and they are OK if somewhat delicate. They are unusual in working off AC and having build in diodes. They also use the same sort of switches as Peco types.
I am actually looking to buy ten more of these Conrad motors but don't want to send off to Germany for them. Does anyone know of a place in England where I can get them from? Robert.
Brian Considine
post 26 Oct 2008, 06:59
Post #5
Chief Penguin
Group Icon
Group: Moderators
QUOTE (Robert Stokes @ 25 Oct 2008, 17:01) *
AFAIK Conrad have an outlet in the UK - the details are "buried" in their website.
Regarding Peco/Seep v slow action if you want extra reliable switching the Fulgurex ones actually work out less than the Peco ones with the extra decent switches.
Take care & enjoy life.
Rowan
post 26 Oct 2008, 07:35
Post #6
Engine Driver
Group Icon
Group: Plus+
I have not heard of Conrad and can't seem to find them, any one have a link please, thanks.
steam-driven boy
post 26 Oct 2008, 08:46
Post #7
Engine Driver
Group Icon
Group: Plus+
Hi, I've been looking at the Hoffman (is this the Conrad under another name?) point motor as I have a similar installation concern on Solsbury Hill.
http://finneyandsmith.co.uk/finneyandsmith/hoffman.htm
The Tortoise does seem to be the unit of choice from comments I've seen posted elsewhere but I intend to try some of these out, if Santa has me on his 'nice' list unsure.gif
If anyone else has any experience of these I'd be glad of a heads-up on that.
Regards.
... being a bear of very little brain...
My N Project: 'Solsbury Hill' Track Plan
N Vehicles For 'Solsbury Hill' Solsbury Hill N Gauge WB
Robert Stokes
post 26 Oct 2008, 12:24
Post #8
Station Master
Group Icon
Group: Plus+
The Hoffmann does look to be the same as the Conrad but it's about twice the price.
Doug
post 26 Oct 2008, 21:35
Post #9
DT
Take a look at this topic: http://www.modelrailforum.com/forums/index.php?showtopic=979
I've tried the Conrad motors and find them a little too fast and tricky to install. They are only about 7 Euros each.
I prefer the Tillig motors that have options for frog polarity and control panel lights.
Robert Stokes
post 26 Oct 2008, 21:51
Post #10
Station Master
Group Icon
Group: Plus+
The speed of conrad point motors, like the speed of any of the slow action type, can be controlled by altering the voltage supplied to them. I also found them too fast when given 12 to 16 volts. However, at about 7.5 volts they are quite a bit slower and quieter. I have a plug-in AC to AC transformer which has a control to alter it from 3V to 12V in steps of 1.5V.
Doug
post 27 Oct 2008, 07:47
Post #11
DT
QUOTE (Robert Stokes @ 26 Oct 2008, 23:51) *
That's a good idea. I have a 16 volt bus that I use for points. Perhaps I could set up another lower voltage point bus to use some of the Conrad motors that I now have spare.
Brian Considine
post 27 Oct 2008, 08:40
Post #12
Chief Penguin
Group Icon
Group: Moderators
We have a few Fulgarex on SL - running at around 10v - much better speed & just about audible.
Robert Stokes
post 27 Oct 2008, 13:37
Post #13
Station Master
Group Icon
Group: Plus+
Doug, if you have any Conrad point motors that you no longer want, then I will be happy to pay £3 each for them.
Cheers, Robert.
jasp
post 8 May 2009, 09:23
Post #14
Ticket Collector
Conrad point motors are available to order direct from Conrad www.conrad.com and click on the GB flag. They are currently £6.95 each or £49.90 for 10 less 10% first order plus £4.95 postage making a total of just under £50 - sounds pretty good value to me
Jim
jim s-w
post 8 May 2009, 09:47
Post #15
Station Master
QUOTE (N Gauge James @ 25 Oct 2008, 11:30) *
Hiya
You can mount them sideways and remotely using these
Remember to be truly prototypical not all point motors in the real world are slow acing like a tortoise. Some, such as the westinghouse EP ones do smak the point blades around with a very audible bang!
HTH
Jim
Jim Smith-Wright
2 Pages V   1 2 >
RSS    Lo-Fi Version Time is now: 22nd May 2013 - 02:19
