 Forum Rules Guidelines
2 Pages V   1 2 >
> Just beginning...
Matt Jackson
post 11 Apr 2012, 21:08
Guard
I've only got a pokey flat above shops, so there's not too much space. A corner layout seems to have more interesting possibilities, but I have no convenient corners, so it's going to have to fit in a rectangle, 200x75cm about the largest without it getting obtrusive. There's a nice corner area on the landing, but that's shared space!
Time period: vaguely 50s/early 60s, for a nice mix of steam and diesel, as well as perhaps the odd ex Big Four stock as yet unpainted and still in regional livery.
I want continuous running, so in the limited space that means some sort of oval. I don't want it to look too "ovally" though, so to alleviate this a sizeable section will be in a tunnel, as well as some reverse curves, and not less than 2nd radius.
After some careful design mucking about with SCARM I eventually came up with this:
SCARM file here (usual right-clicky download)
The stepped part on the left is actually a sloping access road.
As this will a home layout, I initially decided I didn't need a fiddle yard. However, with the long tunnel section, there will be the need of access to deal with possible (inevitable!) derailments, so I put this section behind a backdrop. The upshot of this is that it this area can now be used as a fiddle yard if need be.
I'd prefer to have the crossovers between the inner and outer loops further out from the station to allow access to the sidings without completing a circuit, but don't see how I could fit them in.
Chinahand
post 11 Apr 2012, 21:26
Railways Czar
Group Icon
Group: Plus+
QUOTE (Matt Jackson @ 12 Apr 2012, 05:08) *
Hi Matt,
Have you thought of using two curved points back-to-back to create a cross-over within the bend.
Trevor
See my
Market Havering Blog
RonLaden
post 11 Apr 2012, 21:35
Station Master
Group Icon
Group: Plus+
Hi Matt,
That looks very nice indeed, you have the continuous running (a must for me) and operational interest in the yard and shed areas, good luck with it and keep us posted on progress.
Ron
Swamp Locos
post 11 Apr 2012, 21:54
Post #4
_____The 2nd Sealion_____ ____on the grassy knoll____
Hi Matt & welcome,
Jay
Chris Ridout
post 12 Apr 2012, 08:51
Post #5
Fireman
Hi Matt and welcome.
The layout looks good and goes to show that interesting and functional layouts can be created even with limited space. Looking forward to seeing the progress..
Chris
David Todd
post 12 Apr 2012, 08:54
Post #6
Minister of Transport
Group Icon
Group: Plus+
Morning..... smile.gif Welcome the club......Matt.... biggrin.gif biggrin.gif
........dt........
Link below,is to my layout, Dover Priory and Town Yard.Kent Uk
https://www.modelrailforum.com/forums/index...showtopic=20477
]Click this link and watch my Naff Video Company,clips,of my layout
http://www.youtube.com/user/ferriesdover/videos
Brian Considine
post 12 Apr 2012, 08:58
Post #7
No Longer Active.
Group Icon
That's a lot in a smallish space - well thought out. Look forward to seeing the progress.
Matt Jackson
post 27 Apr 2012, 19:19
Post #8
Guard
Been making a few alterations to my plan... the diamond crossings have been eliminated from the fiddle yard, and incorporated a couple of crossover points there. This needs 5cm to be added the width of the board. (in all, 0.8m x 2m or 2ft 7.5in x 6ft 7.7in in old money). The loco depot has been altered, with a roundhouse style engine shed. I've sacrificed a passing loop so the outer line can now be accessed from the sidings without a full circuit, and the station is now an island platform.
As I'm in a flat with a twisty staircase, a large board would be awkward to get up and down without damage, so I think it would be better for it to be in two parts (magenta line is the split). Just wondering if there would be any issues with the wiring getting too "busy" with a pair of points to either side. question.gif
Mike-Greg
post 16 May 2012, 14:48
Post #9
Guard
Better to check your radius there with your stock
I have 1mtr width and thought that would be ok
i should have check it but didnt ( just layed track as fast as i could )
well it is for my tanks and BO/BO but the steam jobs with boggies bind something terrible on these bends and the larger one wont go round at all
and i only have a single track ( no inside line )
find a space were you can lay the track temp ( even on the floor with blue tack holding it ) and try the radius with all your stock
if i had done so i would have added another 30cm to my width ( to late now expencive ply is cut glued and screwed )
have had to change my plans and will probably end up selling the steam jobs of on ebay
Matt Jackson
post 16 May 2012, 17:05
Post #10
Guard
QUOTE (Mike-Greg @ 16 May 2012, 15:48) *
This is in N gauge, it would be too tight in OO!
Matt Jackson
post 31 May 2012, 21:12
Post #11
Guard
Construction under way...
Critical part is getting the middle panels straight with the base join, it's straighter than the photo makes it look.
Living room a bit of a mess, oh for some proper workshop space!
spurno
post 31 May 2012, 21:36
Post #12
Station Master
Group Icon
Group: Plus+
hi Matt
baseboard construction looks tiptop.love the roundhouse.
Chinahand
post 1 Jun 2012, 02:39
Post #13
Railways Czar
Group Icon
Group: Plus+
Great bit of joinery Matt. Those baseboards look very professional.
Trevor
See my
Matt Jackson
post 1 Jun 2012, 18:42
Post #14
Guard
Errrm, thanks, but there's very little actually joined at this point! It's just loosely placed to make sure things go in the right place.
The two middle plates are held together with coach bolts and wingnuts (need to get some cabinet dowels before separating!), and some corner inserts that the top will rest on are screwed in place.
The timber supplier I used have a cutting service, and are pretty accurate! The lot cost me 48 plus 5 delivery.
Unfortunately, this evening's construction has been cut short due to broken drill bit, a thin one for drilling screw pilot holes.
Chinahand
post 1 Jun 2012, 18:49
Post #15
Railways Czar
Group Icon
Group: Plus+
QUOTE (Matt Jackson @ 2 Jun 2012, 02:42) *
Yeah. Been there, done that. I now buy half a dozen at a time and top up my stock when I get down to the last 2.
Trevor
See my
2 Pages V   1 2 >
RSS    Lo-Fi Version Time is now: 19th April 2021 - 21:10
