Reverse order again…Hornby cheap 08
there are any number of good class 08s I own sone, but I wanted a weathering project so I bought a cheapie,look closely and you can see much is roughly hand painted I could have taken more time but I like quick returns
I added black to the front grill, weathered the top
I added glazing glue for the windows I always get a circular centre as I turn it over adding more glue but taking the top off to add plastic sheet is fiddly and painting a window was fun, I applied with a lolly poppy stick one end curved the other end sharpened, the edges tend to be thicker then get thin towards the centre you can thicken the middle but so far not been impressed with that so just use as little as possible to get the job done
missing detail,so I slapped some paint on
some areas appear darker I s,ap water on add paint let dry repeat until happy, if wet stop or add dulcote or similar, if dry powder finish in similar colours DD Concepts powder works well here
usually when weathering I keep the project in the upright position imitating rain fall but I wanted extra depth so broke my own rule
a transparent orangey brown infers dirt and rust FYI nowadays I tend to download reference pictures as so fed up with not being able to show them, I ask when I can.
reference pictures to my mind are not optional, if you want to get the feel you need the real
that clunky joiner could go made but the point was go cheap so I left it dulled it down and in later photos hid it behind some scenic item
on the work bench
as bought on the layout, can pass muster,but it was always going to be trashed
