00 Goathland
683 Views 61 Replies 5 Participants Last post by  linka
goathland
Hornby Skaledale
Wood Composite material Engineering Brick Metal
Wood Road surface Fence Grass Asphalt
Wood Brick Plant Brickwork Flooring
Vehicle Tire Plant Building Window
Vehicle Wood Track Railway Motor vehicle
Road surface Automotive tire Plant Wood Asphalt
Window Building Wood Road surface Rolling stock
Car Vehicle Tire Window Building
Building Wood Asphalt Road surface Tree
Wood Grass Brick Landscape Gas
  • Love
Reactions: 1
41 - 60 of 62 Posts
As Goathland is filmed for Heartbeat I tend to model that as well
Greengrass
Wheel Tire Output device Automotive design Motor vehicle
no before picture, but ge fr the wet locks, waistcoat and scarf a must
I have seen the correct van but not in 00 or at least not at the time of producing this so I bodged one.
Wheel Tire Window Vehicle Automotive tire
Aidensfield Ar me pub as bought.
Wheel Tire Car Building Vehicle
Wheel Tire Car Vehicle Window
  • Like
Reactions: 1
Tire Wheel Land vehicle Car Window
donor lorry
tried red
Tire Computer Wheel Car Personal computer
better but so RED!
duller better
Wheel Tire Vehicle Automotive tire Hood
better
Vehicle Wheel Automotive tire Tire Motor vehicle
but not right, needs darker
Wheel Tire Vehicle Automotive tire Toy
Wheel Tire Vehicle Automotive tire Motor vehicle
definitly better
much better
  • Like
Reactions: 1
Bridge into the carpark
Sky Window Building Tree Cloud
  • Like
Reactions: 2
Waiting room
i p,an a creamier colour and to add blinds to the windows
Sky Building Window Cloud Plant
Window Train Building Track Railway
Window Building Door Wood Asphalt
  • Like
Reactions: 2
Waiting room
i p,an a creamier colour and to add blinds to the windows View attachment 24364
Hi again Jaz,
When you first posted the low level platform view, showing the platform surface and edge stones, kept meaning to ask what you modelled these from; as look so realistic ?
Other pics look great too of course 😉.
Thanks, Cheers Norm
  • Like
Reactions: 1
Platform / foam
Hornby platforms are fine for a small length,but especially when you want to model a real place you have to look at other solutions
Having insulated the roof,then found ways to use the cuts offs, and making the stairs it occred to us that we might have the solution for the platform and the 25mm thick sheets was just about spot on for depth, bomus
Wood Floor Rectangle Wood stain Hardwood
grabbed a sheet, filed a lip, scalpeled some stone
grabbed a paint brush and sone thin paint to see how it would translate
Wood Rectangle Flooring Composite material Gas
Building Wood Sky House Landscape
Property Wood Rectangle Floor Brick
i should have measured but I just hit it
Building Wood Asphalt Composite material Track
Track Rolling stock Railway Wood Line
checked against the track
Wood Bumper Automotive exterior Hardwood Wood stain
roughly cut sone slopes, I meant to improve but once it was in place never went back lol
Wood Floor Flooring Wood stain Hardwood
Wood Road surface Flooring Gas Asphalt
I tend to slap paint on in light colours then build up if it appears to be working,there is rarely a plan more a seat of your pants
the real slope
Wood Naval architecture Hardwood Automotive exterior Flooring
first colours to define bricks then a wash over the load to grey it down
Wood Rectangle Table Floor Flooring
Window Road surface Mode of transport Asphalt Wall
being foam you can cut and sit the building, the water pumps lamps whatever
if embedding ablock and sanding paper work fast
Water Composite material Landscape Road Metal
very cheap by comparison to building using pkastic kit
Building Window Road surface Asphalt Sidewalk
dulled down the brighter colours are suitably showing the individual stones
I did damage some but reoairs are easy if you can be bothered, sanded foam and glue are one option.
I paint with pvc to harden and strengthen
Track Railway Mode of transport Rolling Thoroughfare
plastic fence just pushed in,if I ever damage it glue will sort it
really need to weather the rails :)
perfect not nit even close, but once you add loads of different factors people are to bush looking at the overall to concentrate on the individual issues
plus I think I was nagged by Richard and used n gauge here as he hates 00 gauge ballast on 00 gauge layouts.
FYI always wanting to try something new when we did Kalborough we tried a different technique, we had left over plasterboard also 25mm the paper finish was paintable but if it soaked up too match watery paint could be an issue, and aligning the peco edging was more problematic but not beyond our patience to fit, then ballast to bed
Track Building Wood Tree Mode of transport
Wood Rectangle Composite material Flooring Technology
tried this plastic sheet, the cost and embedding was more problematic and not very weight bearing gave up on this idea quite quickly
Wood Rectangle Musical instrument Flooring Hardwood
the plasterboard obvious carried weight easier, and as we could paint we tried different styles, these were basically referenced from Peterborough station
Train Track Wood Road surface Railway
Wood Rectangle Composite material Tints and shades Parallel
a blade cut the slabs then painted carefully, the slopes involved cutting the plaster in the plasterboard which was messy but not too difficult
Track Wood Railway Rolling Line
Plant Rolling stock Tree Asphalt Road surface
Wood Track Rolling Railway Thoroughfare
Transport hub Road surface Asphalt Composite material Thoroughfare
I could also mark the board for embedding the buildings
Track Rolling stock Railway Wood Rolling
and the board was soft enough to press some detailing into place
all in all I think I prefer the foam, and all that peco edging added up in cost, but either did the job
  • Like
Reactions: 1
And for reference Kalborough
Automotive parking light Automotive lighting Vehicle Car Motor vehicle
Train Vehicle Rolling stock Plant Tree
Train Road surface Infrastructure Asphalt Track
Train Vehicle Transport hub Rolling stock Track
Train Track Wood Rolling stock Mode of transport
Train Transport hub Vehicle Rolling stock Building
Rolling stock Track Wood Railway Mode of transport
Infrastructure Track Asphalt Mode of transport Wood
Tire Wheel Automotive tire Tread Automotive lighting
Vehicle Automotive lighting Automotive tire Road surface Car
  • Like
Reactions: 2
Hi Jaz,
Thanks for all the pics / info. Think the 25mm cut / scribed rigid insulation is a good call.
On the “Loft” had used small timber as the base and thin ply as the top, for platforms about 4-6ft Long; but never been right, with banana ends in the sunshine / heat - as some early Loft Posts / Humour -
Given the rigid / PIR insulation is available in thicknesses from 6mm to 200mm at least, and more, will take a look or even see what’s in the garage ....
No doubt more questions WIP to follow - Thanks again Cheers Norm
  • Like
Reactions: 1
If it has metal strip remove both side, as that is vulnerable to heat and can banana also once metal foil is gone it’s fine
  • Like
Reactions: 1
I wanted to detail a butchers once upon a time before elf and safety got in on the act, you could regularly see meat hanging from the butchers,Xmas York hams and turkeys and even sides of neat
pink plastercine
shaped
then painted
white fat and flesh pink added
selling the back of a lorry was not unusual,and not always netted either
  • Like
Reactions: 1
Hi Jaz,
Again some really great detailing / models - meat and poultry being displayed / stored for sale like that evokes lots of memories - elf and safety apart we all ate it and lived to tell the tale eh !
We still have a few village shops (butchers, fishmongers, bakers),that still to not “too” long ago had shopfronts / windows like that - inc fish / crabs / etc - only hours out of the sea !
Very impressive detailing as always, Thanks for posting, Cheers Norm
Ps. Wouldn’t fancy being that delivery driver / lifter 🤣 !
  • Like
Reactions: 1
cork tile painted, then a ruler and sharpie then a ruler and yellow paint
add bridge sides
added a bit more dirt
before additional dirt
cirk tile and grey paint first layer
peco plastic sides
  • Like
Reactions: 1
oops forgot to add reference…need to pay more attention lol
  • Like
Reactions: 2
this was the original sandstone effect for the cliff by the church
but it was more USA than UK so an update
using real living plants that worked for the gauge
a darker grey layer
and blacker deep shadows toning the terracotta down
adding mosses and textures
static grasses long and short
ok the fog is a bit ott
lichen
checking and looking for obvious model shoutouts
like floating gravestones
Improving spots hiding any floaters etc
  • Love
Reactions: 1
FYI my technique when taken a photograph is not to look at the best bit, but look at the worse bit and see if it is an easy fix in order to improve the whole,.
  • Like
Reactions: 1
Hi again Jaz,
Think mine would be take it in the dark, or ask someone else to take it 🤣
  • Haha
Reactions: 1
Hi again Jaz,
I did a short photography course, I can help with that as well,what do you use to take photos,and what other options do you have
  • Like
Reactions: 1
41 - 60 of 62 Posts
