Thanks, StuB. Quick answers to your questions:
1. I have not tried jointing the copper tape for precisely the reason you mention - I believe the adhesive would act as an insulator so there would be no connection. I did consider trying to scrape some of the glue off and then taping over the top to hold the joint but wasn't convinced it would work.
2. I solder once the tape is in place, then paint over the top. In future I will look at putting the tape between the layers of card or under the texture layers (as seen on the signal box roof) so there are minimal bits exposed.
3. It should be possible to solder the LEDs/wires to the tape prior to fitting as the tape is backed with paper which is then removed to stick the tape in place. I wonder if this would be even more fiddly, though.
4. As you can see I've not soldered since School 25 years ago, but I wouldn't have been that concerned about melting the plastic just putting a wee blob on to make an adequate connection for an LED.
Sarah is correct, the box is the Scalescenes one with Brassmasters windows/lever frame and some small details added from the Scalescenes furniture pack & other kits.
For more of my experiments in lighting see my thread on pages 2 & 3. I'm particularly pleased with the last picture in post #30 and the ones in post # 33.
