Hello
I got to thinking about how long Anyplace to Anywhere you like might take…… That didn't quite fit into the original intention …. To get a layout which could be made in a, relatively, short time … a layout which can be used to learn an few things. ....
The concept of the Anyplace to Anywhere layout is simply a OO railway for my 7 yr old girl to play trains and learn a few things as she does, hence the name. I have collected a number of trains that she and the family have been on and other bits so she can role play and also worked out some card based games to be played out on the layout, including an Inglenook Sidings type. ....
http://www.modelrailforum.com/forums/index...showtopic=24091
It also has to be capable of quick setting up and packing away, therefore not joining up loads of rails from a box every time .... Nothing has changed …. BUT …. She is quite a time away from using it because of the time it takes to build it and I would rather get her involved in, at least, part of the intended plot rather more quickly …. So ….
I remembered the size Ingleton Sidings [ an Inglenook variation ] I had seen at the Bentley show in Melksham … she likes a puzzle or two, so I thought a quick interim shelf Shunting Puzzle [ Shunting on a shelf .... pleeease! ] might be good.
I also need it to be very light .... so construction was relevant too …. Enter the Mosquito and Vampire … made from Ply … add in model a/c foam / ply [ or Balsa ] sandwiches …. There is an idea forming….. Here is the start ........
DSCN2364 by JulianR 2013, on Flickr
…. 40mm insulation foam in need of stripping down naked with enough Ply to cut 2 x bits of bread for the sandwich ...
… then a layout plan on Anyrail …. Measure the windowsill … gives me 48" x 8" …. Look in the spare rails pile and find I have a curved set of Electrofrog and a short Electrofrog Y …… pull them onto the plan and mess around with lengths to make sure I have room for 5 x trucks on the long siding and space for 3 x trucks on the other 2 sidings.
The Plan
Shunt Plan by JulianR 2013, on Flickr
In fact there is a slight change ..... already .....
.... as you can see from the plan, the tracks run through the Goods Shed on the side away from the goods doorway, with the loading platform next to the door .... the goods shed is now the Great Northern Skale Regis one ..... it has the rails through the shed next to the open door .... so little fingers can reach through to load the trucks with appropriate items .......
Those with sufficient remaining levels of eyesight [ or suitably recent assistance from the Optician ]
and good levels of observation will, of course. have noticed thet there is some pink area and some white area ......
The pink is for the location of the foam .... which leaves the white area, where there is to be no foam ......
.... this space in the foam will house the electrickery and a Frog Juicer for each set of points ....
.... I could have run the Droppers through the whole board to the underside, as it is only a total of 48mm thick all told .. but .... that recess should keep it all tucked up out of the way .....
So far the sandwich has been made, rails cut, Droppers soldered, holes for the Droppers drilled, most of the 2 x types of Underlay glued to the Sleepers .......
then I ran out of one type of Underlay and had to order some more .......
..... ordered some more .... but ..... can't progress any more yet ........
Anyway .... that's probably as much as anyone can put up with my drivelling on for the moment .......
I would be interested in any [ civilised
] comments on what has transpired so far ........... more pictures and information later, if anone would like to see them ..
TTFN
J
The Plan
TTFN
J
