Temporary wiring was used to test the TT motors, which has now been replaced. The Decoder is now permantely soldered in, as are the TT Bridge power connections and a Resistor, Capaciter Filter [the little blue job on the Well floor] added to the TT Bridge connections, to safeguard against spikes which may be formed as the Bridge Rail contacts slide round to change the polarity of the Bridge rails.
The power supply connects through a screw type choccy block connector, attached to the brass arm [right side in the picture]; all the remaining connections are soldered to connectors fixed to the Motor Unit. It is now possible to remove the Motor Unit in it's entirety, leaving the DCC power wire input soldered to the TT Bridge, in the centre of the Well.
{NB. The polarity change is needed as when the loco drives onto the TT Bridge, the left-hand side of the loco will be on a positive supply rail, but when rotated through the 180 deg, the left-hand side of the loco will be facing the opposite [negative charge] rail. But you knew that didn't you.}
Topside looks like this and and rotates very quietly indeed.
LMR 2-8-0 Austerity got a celebtatory turn, just to be sure and check the TT Bridge rail connections. Actually, it got several... Sshhh!!!
Julian
Julian
