1 - 1 of 1 Posts
Administrator
Font Automotive exterior Magenta Event Sleeve
A1 Hobby Shop Model Railway accessories by Proses
Ballast Spreader HO/OO
Here we have the ballast spreader by Proses, sold through the A1 Hobby Shop in Istanbul Turkey.
"Why a ballast spreader?" you may ask, "it is simple to to it by hand." Well it's not that simple. And testament to that are all the bare track layouts around the land. Getting it right takes practice and is time consuming. If you have a lot of track the task could be daunting.
Wood Track Gas Railway Flooring
This simple gadget does what it says on the tin.
See the little video below to see how simple it is.
http://www.modeltrenciler.com/videopaylas/player.swf
And me, well I tried it on a couple of short straight sections of track that needed ballasting and it worked perfectly. Here are a series of shots showing the ballasting process.
Fill the Ballast spreader.
Wood Rectangle Rolling Flooring Hardwood
Slowly move the ballast spreader along the track.
Wood Track Finger Gesture Railway
And that's it.
Wood Track Flooring Rectangle Road surface
Here, below, I start to wet down the ballast with water (plus a little detergent to break the surface tension).
Track Building Window Railway Wood
Track Wood Building Railway Road surface
I mix PVA with water 50%/50%
Fluid Flooring Plastic bottle Asphalt Bottle
And I drop it onto the ballast with a handy syringe and plastic tube.
Track Asphalt Road surface Railway Rolling
All done. Just let it dry.
Track Railway Rolling Road surface Asphalt
Ballast Spreader N/009/HOe
Rectangle Toy Road surface Gas Waste containment
Note, I didn't use the spreader to lay ballast on the HOe track as it was already laid, but you can see it fits perfectly. 3 adaptors are supplied to give 3 rates of flow or to use different grades of ballast I suppose. The big holed adaptor for HO scale ballast (HOe track) and the smaller holed adaptor for N gauge ballast.
Automotive tire Road surface Asphalt Track Railway
Doug Teggin
June 2010
1 - 1 of 1 Posts
