Accurascale
3240 Views 12 Replies 6 Participants Last post by  34C
Hi All
I recently came across a website for Accurascale, I've never heard of them.
They seem to have a varied selection of rolling stock and some Loco's (mainly Class 37's which cover all the variants)
They are surprisingly well detailed models, if a little pricey for my taste.
Has anyone heard of them, are they worth perhaps in investing in buying ?
Any information would be appreciated.
1 - 13 of 13 Posts
They have released some wagons and have more under development along with a Deltic, 37, 92, Manor and Mk5 coaches ; note the "Pre Order"labelling.
The wagons get good reviews and you are sure to find some on youtube.
We will find out how good their powered models are later this year when either the Deltic or class 37 are delivered.
If you like the look of the products, they will be no more or less risky than those from other manufacturers. The models are all manufactured in the same Chinese production system, and experience shows that perfectly competent designs are not a guarantee of the manufactured product being right. It only needs something as trivial as an electronic component supplied to the wrong spec., a component with inadequate dimensional control, or a minor error or misalignment at assembly. That's the event that reveals the calibre of the business that got the model made.
I am in the happy position of not needing any of their announced models to date, (have Bachmann Deltics with scale diameter wheels, so not impressed at the underscale wheel diameter fudge Accurascale have adopted) so will sit on the sidelines and wait on the 'field test' commentary from the first owners.
Consider that Bachmanns list price for a 37 is £169.95/£179.95, £259.95/£269.95 sound fitted then these are in the same ball park pre box shifting stores discounts
Finally succumbed, a three pack of their 24.5T mineral hoppers as first in service from 1957, (later classified HUO). These are now hid away for the December shindig since I am 'difficult' for presents; but initial impressions are very favourable, and they can be 'visitors' to my KX area, possibly being demonstrated to potential major customers.
  • Like
Reactions: 1
I quite fancy some of these but HUO and other types I like the look of are all sold out, not desperate as I have hundreds of wagons unused but even so....
Succumbed again to some of the bauxite vacuum braked 21 tonners that were recently released, as these showed up in all braked coal trains on the ECML right at the end of my selected modelling period. They were supposed to arrive today, but I doubt there will be a delivery now. (On the positive side these and some other bits and bobs were paid for by selling 20 off reinforced concrete fence posts that I got free about ten years ago; the result of a builder's merchant error in supplying double the ordered quantity, and couldn't be bothered to come and retrieve the excess. It's an ill wind...
No playtime with them likely until Monday as there's a full programme this weekend, commencing with the special (oh be joyful) over 65 flu jab.
  • Like
Reactions: 1
... there's a full programme this weekend, commencing with the special (oh be joyful) over 65 flu jab.
All previous plans are off, goodness knows what they put in the over 65 flu jab formulation this year, but I have never had a reaction like it, very sore upper arm, aching joints, slightly elevated temperature. I suppose that proves it 'did something'?
So I have had some available play time with the 21 tonners, and very good they are too.
I feel Accurascale have made one mistake, by supplying them with tension lock couplers fitted. These are inadequate in swinging NEM coupler pocket mountings, and quickly prove it if propelling. They should consider the Roco pattern 'rigid bar' coupler in my opinion, as this coupler head already has some UK presence via Hornby. The tension lock can be offered as an alternative in the box, with a recommendation that the coupler mount be secured rigid if the tension lock is used. I will write to them on this matter.
  • Like
Reactions: 2
Hi mate,
Phew, sounds like a nasty reaction to your ‘Jab, hope you’re better soon. Did you get the flu jab last year?
My kudos to you for actually physically writing to Accurascale, I hope they take it onboard (sorry, I do hate management speak).
Having experimented extensively with pretty much all coupler designs going, I think it would be great to see if someone like this manufacturer would take the logical next step towards operational reality.
Clearly not a particularly visually realistic coupler but surely better than the tension lock?
Besides the incorrect track gauge, I feel the tension lock coupler is the worst thing in “00”.
My friend Doug, has a thing about propelling his push-pull trains as much as possible. He can run 9 or 10 coach trains around his layout, this is around radius 3 & 4 curves and up and down 1 in 40 grades - perfectly possible with European design close couplers but try that with anything fitted with tension locks and see what happens at the first curve.
Sorry, I’m getting away from Accurascale somewhat but so much British stock is now (sensibly) fitted with NEM pockets, why not utilise them?
  • Like
Reactions: 2
I have had the flu jab every year since it became available, never had a reaction like this previously. Better than actually catching influenza of course; had the real thing once, and that was quite enough. (Had to buy a new mattress after it had finished with me, because the fortnight of sweat staining was simply gross. Too much information?) It will pass.
...I’m getting away from Accurascale somewhat but so much British stock is now (sensibly) fitted with NEM pockets, why not utilise them?
Quite so. When I was pleasantly surprised to find the close coupling mechanism on Bachmann's mk1 coaches, now over 20 years ago, I consulted one of my Dutch model railway enthusiast cousins, and he advised. As you describe, with a suitable 'rigid bar' coupler installed you can stably propel any length of train up to the limit of traction of the loco, and it stays on the rails.
Neither Bachmann or Hornby have ever explained to their customers how to obtain best performance, so far as I am aware. Hornby have at least included a Roco pattern coupler head with their coaches, but on a long mount which doesn't produce the best effect. (By happy chance it compensates near perfectly for the mispositioned (too far inboard) Bachmann coupler pockets, a real moment of serendipity for some of us...)
I still have a use for the crude tension lock in its 'miniature' form however. For the UK's one time crude* unfitted freight stock operation, it is actually a good fit if mounted 'off-standard', which the NEM pocket makes very simple. The short hook of the Bachmann version produces 2mm of slack, perfect for the 6" between bufferheads of loose coupled wagons. Shorten the pocket and coupler mount so the bufferheads and front faces of the 'bumper bars' are in contact when pushing, and there's a scale gap between wagons when pulling, and full protection against buffer locking when propelling around curves. This requires a 30" minimum radius if there are to be no restrictions on LWB wagons.
*I believe the last BR traincrew fatalities from an unfitted freight runaway occurred as late as 1979. Truly unacceptable.
  • Like
Reactions: 2
Well not quite so'
'My friend Doug, has a thing about propelling his push-pull trains as much as possible. He can run 9 or 10 coach trains around his layout, this is around radius 3 & 4 curves and up and down 1 in 40 grades - perfectly possible with European design close couplers but try that with anything fitted with tension locks and see what happens at the first curve.'
My layout has radius 3,4,5,6 on the main loops and 1 in 33 grades, however problems occur through droopy couplings not the system itself, in some cases I have swapped the couplings to Roco/Bemo types as these are better goping downhill in lieu of the droopy things inflicted upon us, going uphill is not an issue as the couplings are in tension but mostly I have little to no trouble sometimes a little work with a file helps and with others to get a better alignment I can use a cranked coupling so this system has multiple options so I do what is cheapest
The pair of bauxite 21T have now had a couple of weeks regular running at the head of a long train, and the W irons which are very finely moulded have stood up to the job so far. (If they ever eventually begin to splay out as some past kit builds did, there is space enough for a metal frame concealed inside.)
1 - 13 of 13 Posts
