1 - 10 of 10 Posts
Hi , as a novice on electronics I need some advice as to whether a project started by my late father which I am trying to complete is viable as per the attached amateurish circuit diagram ( my one and not the Lenz one lol ) .I should explain that I am trying to operate 2 Seep N gauge electromagnetic uncouplers via 2 outputs of a Lenz LS150 accessory decoder and using 2 IN 4001 diodes as per the Lenz instructions to produce a 2 wire output as used for stall motor type points machines , the LS150 outputs approx 15 volts AC from it's initial 16 volts AC supply or rather I think it's an AC output but am not sure if the diodes rectify the current to DC ? ,I want to use the 2 LS150 outputs to trigger 2 non latching relays ( advice sought on type) to provide 18 volts DC to the 2 uncouplers from a seperate and dedicated 18 volt DC PSU , if the LS 150 is still outputting AC rather than DC with diodes in place ? I have a block signalling PSU1 device which can convert the AC to DC and offer 3 12 volt DC outputs to send the signal voltage to the relays , I hope this makes sense as my use of terminology is most likely incorrect ?.
· In depth idiot
You are adding unnecessary complexity. Try using the LS150 output with the pair of diodes to rectify (to half wave DC) exactly as the Lenz diagram for the point motor. I would be surprised if that did not operate the uncoupler adequately.
Discussion Starter · #5 ·
Thanks 34C and Darra , I was aware that I needed to increase the LS 150's pulse to 3 seconds as an initial setting and also needed to give it an address so i'm awaiting the arrival of a solenoid PM to enable me to do so , dad only used Cobalts and the Lenz addressing instructions for the LS150 appear to insist on having a Solenoid PM connected to carry this operation out , as soon as i've addressed it and set the pulse i'll do as you suggest 34C and see if it gives the desired result , i'll report back when i've tested it .
· In depth idiot
But you don't need a point motor to set addresses. Page 26 of the manual explains all. It's really neat, just set an address on the first output, and the other five are incremented +1 with unique addresses.
At this point I should add that unless you really really need remote uncoupling, I wouldn't bother using this or any other decoder. Typically uncoupling is performed in view of the operator, and a simply 'push to make' sprung button is all that is required to energise the uncoupler. My Kadee electromagnets are powered by depressing a piece of phosphor bronze strip onto a brass screw head to make the power circuit. This is cheap and simple.
Discussion Starter · #7 ·
But you need to have a load on one of the outputs to set the master address or so A&H models say in their video of the LS150 , dad wanted complete computer control even down to turning various lights on or off across the layout according to the light levels ( it has sensors at various points ) and i'm not one for playing trains as such but am rather trying to complete what my dad set out to do , please don't think that I don't value your help 34C because I most definately do , as for the Solenoid point motor ? i'm not buying one but rather i'm borrowing one from one of dads friends as i'm not great with electrickery and I can just follow what A&H do Parrot fashion .
Just come across this but, for the benefit of others the Lenz LS150 manual states
"In order to be able to set addresses, the LS150 must be connected to a power supply (AC voltage input ≈) and to the DCC track signal (inputs J,K). You do not need switch machines connected to the LS150 to set its addresses"
The only time you need a load when programming DCC decoders is when programming on a programming track. Accessory decoders are often programmed whilst connected to the layout.
Discussion Starter · #10 ·
Hi , I can now say that I have the uncouplers working precisely as hoped for by using the RL1 twin relay board that has an onboard DCC chip in conjunction with 2 relay timer boards per uncoupler , I had a great deal of extremely helpful advice and even a circuit diagram and advice on components plus a translation of the Chinglish instructions for the timer boards setup from an electronics forum that my late father occasionally used .So I now have what is needed for full computer control of the uncouplers making the uncoupling process entirely automatic ,The RL1 is a really great piece of kit and I recommend it wholeheartedly if relays and DCC control thereof is what you want .If anyone is interested give me a shout and i'll share the details of how to do it .
1 - 10 of 10 Posts
