QUOTE (johnnoble @ 12 Oct 2007, 11:45)
<{POST_SNAPBACK}>As a newcomer (since a teenager many years ago) I am still at the planning stage and have accumulated several DCC ready locos. Having seen that the Lenz silver and gold decoders offer this feature, I was wondering about its advantages in terms of bringing locos to a halt before a point set against them using their cheap BM1 module with I guess appropriate wiring from the point motor switch. There also seems to be the possibilty of an auto stop at a terminus. Does anybody have any views or is their a better way of acheiving the same end, particularly to avoid derailments at points. Incidentaly all my locos will be steam and I gather that space can be a big issue with for instance the Hornby M7
John,
I have a layout which at the moment uses 7 Lenz BM1's. My 4 locos are fitted with the new Lenz silvers which are suitable for ABC. I have a main 4 platform station which is 60" long, two up and two down. At the end of each platform is a Hornby red/green light. I have made up a circuit board for each light which includes a relay and a BM1.
My control box at the far end of my layout is fitted with a push to lock switch and a bi-colour (red/green) led. The track is suitably cut as per requirements listed with the BM1.
If the control box lamp is red, then the BM1 circuit is open, and the train is stopped at the lights. When pushing the switch on say platform 1, the light on the control box turns to green. At the same time, this switch operates the relay which in turn shorts the BM1, turns the light green, and the train now takes off from the platform.
I have a further two platform country station which is also 60" on the other side of my layout, and this is also fitted with the same circuits on each platform.
One part of my layout goes through a wall and into another area, before comimg back through a tunnel. I wanted to delay its return when necessary, so I fitted another light and circuit in there just before it enters the tunnel.
As has been mentioned, the distanced required to stop, is that set by the 'constant braking distance'. On the Lenz decoders, this depends on the top speed of your train (28 steps), and is already preset. I started with two Vi-train 37's and these required a distance of 60" if left running at their top speed. The distance can be measured by running your train at full speed (28 steps) and then at a predetermind spot, shut the speed down to zero instantly. This is the distance required for the train to stop at the required postion in front of the lights. I found that the first cut in the rail (r/h) needed to be 3" before the start of the platform. The l/h cut can be anywhere after the light. ie the nearest join.
When I purchased a Bachmann class 47, I found that it was overshooting the light because its top speed was higher. It would stop properly when the speed was set to 26. I then programmed CV 5 to reduce its stop speed.
Basically, what I do is to set all engines to full speed. I then act as signal man by changing a light to green, and the train starts up and travels to the next stop where it stops automaticaly at the next light. All my trains run from point to point totally controlled by the lights. If you want a fast train, then all lights on its route are set to green. The benifit is the you are not controlling the trains by the controller - that is not touched at all unless I am shunting the 08, or bringing a goods into the yard. The main operation is purely signal box control of lights and points. If I make a mistake, it is usually a wrong point setting and I am trying to put a train into an occupied station.
The size of the train makes no difference to the stopping distance. I have also run a set of Hornby Pullman coaches with lights. This makes no difference to the system at all.
I have only managed to operate with the trains travelling and entering stations at full speed. I understand that it is possible to program the CV's so that the stopping distance is the same at any speed, but I haven't found at how yet as I have been too busy playing. At the moment, if a train enters at half speed, it stops within a quarter of the distance.
Be wary of other decoders that claim that they can operate ABC. I asked one manufacturer who's decoder made the claim but does not work why, and he stated that only lenz decoders will operate, as Lenz have not yet released the software, and they offered to upgrade free of charge when available.
Hope this helps.
