Auscision Models EL Class Locomotive
1434 Views 7 Replies 4 Participants Last post by  neil_s_wood
Auscision Models have shown some pictures of the final samples of their EL class diesel locomotive. I saw a sample of this at the Melbourne show and they were very impressive.
Here are some pictures from their site.
This is a picture of the mechanism
And here are some CAD shots
All pictures are courtesy of
1 - 8 of 8 Posts
Very nice. The light blue hoses on the front remind me of Davy Jones from Pirates of the Carribean.
Something wrong with the cogs...
The worm gear from the motor shaft drives a cog with about 20 teeth. That then drives two cogs, one with 13 teeth and another with 16 teeth. They in turn drive one axle each from a 14 tooth cog. Surely one axle will turn at a different rate to the other?
QUOTE Surely one axle will turn at a different rate to the other?
Now that you say it, I think you're right. Unless they actually intend to fit the centre axle with a different gear wheel, there's going to be a problem.
QUOTE (Doug @ 7 Aug 2007, 05:22) <{POST_SNAPBACK}>Something wrong with the cogs...
You've got an eye for detail Doug.
It might be worth seeing one of these run before buying one then!
Here's some pictures of the final samples with paint on. The detail looks very good on these.
That looks really good - has the gear "problem" been sorted or was that a CAD version of a typo ?
QUOTE (dbclass50 @ 3 Oct 2007, 17:33) <{POST_SNAPBACK}>That looks really good - has the gear "problem" been sorted or was that a CAD version of a typo ?
I'd say it was a CAD version of a typo. I'm sure they must have test run it by now.
1 - 8 of 8 Posts
