***Hi all
A problem has been solved for many owners / brands of DCC!
I've been doing some testing on a neat little product, the NCE Auto-SW.
it is a simple device that can be added to the output of many DCC systems. This is an item that I think will be a big help to owners of systems without dedicated programming track outputs - no more programming all by accident, no more need to take other loco's off the track to read CV's or do programming!
Connection is simple:
It has input on one side from the DCC system (track outputs)
It has two sets of outputs on the other side, for programme track and connections to track.
I have attached an image of it at the bottom of this post.
Its really easy and convenient, as there is no need for a programming track switch at all.
connect to the main track as normal
and
connect the programming track outputs to a convenient isolated siding that you will use as a programming track
Now when you want to do service mode or programming track mode programming, you just:
(1) drive the loco into the siding and stop it.
(2) Put the system into programming track mode (service mode). The Auto Switch will then automatically disconnect the DCC system from the main track track and remain connected only to the programming track so you do not risk reprogramming everything on your layout.
(3) When you finish programming, it will automatically reconnect to the main track so you can just drive the loco away!
NCE say this about it:
Prevents accidental programming of ALL locos on your track when using Program Track mode. Automatically disconnects your main line when in Program Track mode (does not affect Program on Main). Compatible with ALL DCC systems such as DigitraxTM Big Boy, Empire Builder and Bachmann EZ-CommandTM.
I have now tested it with Dynamis, Digitrax empire builder and of course the NCE Powercab. I am pretty sure that it will work just as well with Roco and others!
It is very easy to understand and set up, and isn't dear at all... quite low cost in fact (appx GBP13, $AUD 29).
An accessory with real value to many DCC users!
and
