Greetings. Two apologies first off: 1) sorry if this has been dealt with already, as it must be pretty basic,and 2) I may get the technical jargon wrong because I'm learning about DCC in French, as I live in France, so please be indulgent!
I'm trying to automate a hidden section of track so that a train entering it can be stopped in a siding, thereby triggering the departure of another train which comes out of the same tunnel mouth but in the other direction. The attached diagram should make this clear. Sorry that it's in French, but I got it out of a French magazine. The "zones de coupure" are the portions of track where the current is broken when a train is to be stopped. Four trains can be handled by this set-up. The points at the top stay in whatever position the departing trains leave them, while the points near train T3 are switched automatically to send incoming trains into the siding or let them go straight on. I'm sure this is pretty standard stuff.
Now for my question. In this magazine, a solution using relays is proposed, but my model train supplier tells me that as I have the Roco Z21 (black version) I ought to do it using computer software instead. I'm happy to go down this route as I'm less than useless at all things electrical, and it seems to make sense to get the most out of my Z21. Apparently I also need a Z21 detector to provide feedback on the position of the trains, but then I'm stuck as to how this information is used to tell the trains what to do. It seems I need to install train control software on a PC, but I don't know whether there is a specific software that goes with the Z21 (I haven't been able to find this information on the internet). One such software is iTrain, for which I've downloaded the manual, which seems to get very complicated very quickly. Would this be a good choice? Can I use it to obtain the automated result described above? Any insights would be most welcome!
