QUOTE (Matthew Peddlesden @ 26 Mar 2008, 23:58)
<{POST_SNAPBACK}>Not sure about the accuracy of this statement - certainly it's true for the Select, but as the Elite has an NMRA conformance warrant and i've certainly not seen any compatibilty issues with it, I don't see how it applies to the Elite.
Looking on the Bromsgrove site it seems that the NCE Powercab comes with a US power supply, so factor that on top of the £92 price - and compare to DCC Supplies £97 for the same unit *including* the UK power supply. I didn't see any info on the Bromsgrove site about where to get the UK power supply from or how much it might cost and i'm sure they'll tell you if you ask, but it's just something to watch out for.
http://www.dccsupplies.com/shop/product_in...products_id=487
That's very interesting indeed, I've looked on the NMRA C&I site and I can find an entry from 2005 for NCE Power House Pro (2005-011) is that the same thing?
It looks like a neat little unit. What "language" does its bus talk? Is it a proprietary one for NCE devices or one of the others like Xpressnet?
Is there are computer interface available for it yet? The bromsgrove page says "optional usb" but I haven't yet seen what the device is and the cost or whether that works with the power cab as opposed to the bigger system.
Matt.
***Matt, you need to understand the whole history of Hornby DCC to comment. MMAD's comment was fair in the context of the general "hornby experience" which we all sincerely hope will be come better and better as time progresses.... but it has a long way to go.
Fixing the Elite was a really good start! Elite does now have a conformance warrant and I was really pleased to see that as the inital releases were not conformant or compliant... however the Select is still a disaster of a product and the decoders are only now starting to become reasonable - and there are 10,000 or more "faulty" selects out there and only god knows how many very flaky decoders out there (Both so far off NMRA Spec that they aren't even entitled to be called DCC) that hornby still deny are a problem.
As to the decoders, they are a "work in progress" at best.... in fact their last revision isn't due until later in April (I understand it will have a yellow dot on the processor). Hornby chips remain a problem, as does hornbys DCC wiring on occasion...
For example I had a customer only last night who had bought two "chipped" hornby loco's as they were the names and numbers he wanted. He removed the hornby chips as they performed badly and anyway, one had failed within minutes...then discovered when a replacement chip was destroyed that BOTH locos had what were serious shortcomings in the wiring.
So... a Hornby loco that was supposed to be "DCConboard" therefore OK also killed a TCS chip that I ended up having to replace under the goof proof warranty but it was not my customer, myself or TCS who was in the wrong, it was Hornby, who again get a free ride for their carelessness and mistakes. Thats the sort of thing that MMAD meant by "the hornby experience".
The recommendation: This is not a conformance, feature or any other sort of "peeing up the wall contest". Feature listings are not the point, usability and general "human interface" issues are.
Recommendations should be specific to the questioner, not "do as I do" as one mans preferred controller type will not suit another.
The important fundamental difference between the NCE and the Hornby is in a couple of areas. One is console, the other walk around type. NCE has a very instinctive interface plus direct access to 28 functions via its handset, and is one button access to all importantfunctions: Elite is multi push for functions, which is not really a sound loco compatible approach that most enjoy.
You question the busses: It is no big deal - xpress net is nothing very special compared to NCE's very stable bus format. Lenz's relative position in the world market is anyway clearly in decline. Xpressnet is not a quality or standard reference.
You ask about power supplies: The power supply provided with the NC PowerCab is universal floating voltage. It works in UK or anywhere else as well as it works in USA.
You query the computer interface: the USB adapter is for PowerCab only and works well. It was pre-tested with popular computer software for train control prior to release. The full spec NCE system has had direct system computer interface for a decade.
You query the conformance: NCE PowerCab DCC related electronics are a subset of PowerHouse Pro electronics so also comply... NCE has always complied from day one of its existence. (PowerCab = ProCab + miniaturised base station, the two are operationally identical)
Overall its good to be enthusiastic about the unit you have but you present your post as a "defence" of Elite which was never being attacked in the first place: It is now a much better product than when released, and it is in fact good value for those who want a console type controller.
The comparisons given are based on real world hands on experience of all systems mentioned. Conclusions and recommendation by me to go for the PowerCab are not because Elite is not adequate, but because PowerCab is better for the specific need as stated..
DCCconcepts
