1 - 1 of 1 Posts
Administrator
Bachmann Class 57XX BR
Pannier
Model number: 32-211. Black,
Early BR emblem.
Review, DCC decoder & Kadee installation by
Doug Teggin
Train Wheel Vehicle Motor vehicle Rolling stock
The Prototype
The Great Western Railway (GWR) 5700 Class
is a class of 0-6-0 pannier tank steam locomotive, built between 1929 and
1950. 863 were built, making them the 2nd most produced British class of
steam locomotive.
The GWR had
favoured Pannier Tank locomotives since 1911 when they had started
rebuilding locomotives built between 1870 and 1905 into this style. By
1929 these older locomotives were in need of replacement.
The first 5700s had round spectacles in
the cab front but those built after 1933 had rectangular windows and a
slightly different profile virtually identical to the style introduced
with the GWR 5400 Class in 1931. Whilst they can be viewed as a simple
update of the GWR 2721 Class, the Collett improvements were worthwhile and
the class became as synonymous with the GWR as Castles and Kings, lasting
until the end of steam on the Western Region of British Railways.
Source Wikipedia. Photo:
By David Wainwright
Train Vehicle Rolling stock Nature Steam engine
The Bachmann model
I was looking for a transition period steam shunter to use in my
yards. We all seem to have too many mainline large locos and not enough
smaller tank engines and shunters. I like detail and I aim for quality. I don't want a
train set 0-4-0
or a 0-6-0 that will have bad handling qualities on the layout. So many of
these little engines tend to be cheap and nasty. So I was very happy when
I found this Bachman Class 57XX BR Pannier. Click on the images
below for larger versions.
Train Vehicle Wheel Rolling stock Track
Train Rolling stock Track Steam engine Locomotive
A great model with plenty of detail. Good
value for money and relatively easy to get hold of in shops and on eBay.
Will it run smoothly and slowly? Will it haul a couple of wagons and
coaches around the yard?
Train Wheel Vehicle Rolling stock Track
The loco model is substantial. A metal
chassis and metal weight inside the plastic body located in the water
tanks on either side of the boiler. The details that surrounds the model
moves it out of the train set category: Hand rails all around the loco,
filler lids on the water tanks, great cab detail, tool boxes on the rails
and brake rods that add visual detail to the 0-6-0 wheel set.
Land vehicle Vehicle Car Motor vehicle Automotive design
Train Wheel Vehicle Rolling stock Motor vehicle
DCC decoder installation
Opening up the loco is quite
simple. Two screws on either end of the chassis on the centre line. The
body is a little tight, but it comes off without any damage to any parts.
Looking inside the loco, we see a PCB that holds the capacitor and a
couple of chokes. No NEM DCC socket, but it doesn't look like a problem to
hardwire a decoder.
Train Wheel Vehicle Window Rolling stock
Initially I thought that a Lenz 1014 decoder
would do the job. I had to cut off the two metal posts that the screws for
the PCB screwed into. A Dremel with a cutting disk made short work of that
job. I wired it in, but I found that the slow running of the decoder and
loco was not slow enough. For a shunter, you want good slow motion so I
found a spare Lenz Gold. The Lenz Gold has this thick socket for the wires
so it was a bit too thick for the space available. So out with the Dremel
again and a little more cutting.
Train Wheel Vehicle Motor vehicle Toy
Circuit component Hardware programmer Passive circuit component Engineering Computer hardware
Some double sided tape insulates the decoder
from the chassis and secures it in place. The width of the decoder is just
right. A Hornby decoder, a Bachmann decoder or any smaller decoder would
probably fit without cutting. I wirded the decoder and tested the setup on
the programming track. All fine.
Wheel Train Vehicle Motor vehicle Automotive tire
Wheel Train Motor vehicle Vehicle Toy
The service sheet does recommend that the
loco be run in for a period. So I set the loco onto the rolling road that
is hooked up to the DCC layout. I have found a great grease that I use on
my fly fishing reels. It is red so it shows up well where it is spread.
The Quantum Hot Sauce grease makes a big difference to the running and
smoothness of the gearbox. Here, on the bottom right, we see the loco in
motion with the grease doing it's thing. It is not going like mad, but the
photo was taken with a 4 second exposure.
Ammunition Rocket Missile Gas Cylinder
Light Motor vehicle Automotive design Vehicle Engineering
Kadee coupler installation
As I'm installing Kadees everywhere these days, I may as well add them to
this loco too. The NEM pockets fit onto the loco when the body is back on
as they cover the body mounting screws. I added a couple of #19 Kadee
couplers. Unfortunately, there is quite a bit of droop of the Kadee in the
NEM pocket so it looked like this on the bottom left.
Train Land vehicle Wheel Vehicle Rolling stock
Wood Composite material Fixture Beige Tints and shades
I cut a couple of pieces of plasticard from
a 0.5mm sheet. 8mm x 3.5mm. These were slipped into the NEM pocket under
the Kadee effectively raising it up and eliminating any slop in the fit.
Now the height is just about right. See on the bottom right how it
measures up to the Kadee height gauge.
Beach Sand Soil Landscape Metal
Train Vehicle Wheel Rolling stock Motor vehicle
After a couple of hours of running in,
running it on the rolling road forwards and backwards, this loco is now
moving very smoothly indeed. It hauls well and negotiates my points
without problem. It did stop on a large radius bend and I wonder if the
copper pickups are tight enough. I'll bend them a bit more just to be
sure.
This loco will be a permanent
feature of my main yard. Perhaps I'll have to find it a partner to keep it
company. It may have to be another Class 57XX as what else is there
available that works so well?
- August 2007
Other links:
Wikipedia -
0-6-0PT,
GWR 5700 Class
The Great
Western Archive -
5700 tank class
introduction
GWR Modeling -
A Beginner's Guide to
Pannier Tanks
All text, photos & graphics, unless
otherwise indicated ©2007
Doug Teggin - All rights reserved.
1 - 1 of 1 Posts
