QUOTE (dwb @ 3 Dec 2006, 09:40) <{POST_SNAPBACK}>Re South West Digital sounds
Neil - I wouldn't worry about synchronizing the sound between front and rear of an HST. (SWD announced the HST about a fortnight ago). When I am waiting for an HST to pass at the local crossing, each motor car sounds as an individual. The sound of an HST does seem to be quite distinctive as the engine spins up when the driver sees the green for the line ahead.
Syncronisation would be an issue with the HST. The HST power controller has five notches, all apart from notch one result in an engine speed increase. The power cars rev up simultaneously because when the Driver notches up in the front power car, an electrical signal is sent to the rear power car to select the same notch. There may be a very slight delay due to mechanical differences, but it shouldn't be much.
It does get complicated when you factor in the power car that is producing the train supply (usually the rear one). This power car will not be idling like the other one, it will be at notch two level revs at idle, because of the electical load on it. It would be interesting to see if you can program the chip to do this.
Peter.
(HST Driver for 9 years)
Peter.
