QUOTE (Edwin @ 16 Jul 2008, 23:19)
<{POST_SNAPBACK}>If you re-read my post I think you will see I am agreeing with you. Grouping and WW2 were the ONLY pre-1948 events that influenced all the companies at the same time. All the other events, whether change of CME or otherwise, only affected one company and hence can't simply be represented by an era-type system.
Yes, I see what U mean and yes, that is sort of correct, however even these changes took half a decade or more to really bed in significantly as they were usually accompanied with shortage of funds and practicalities in rationalisation but I don't think thats what they are trying to do at all.
They are simply trying to give a general date grouping for the loco as presented.
No matter what is done in any system there will be both subtle and extreme anomalies, and some will be grouped close to the lines they cross such as the 08 that started this thread, but its a simplistic guide, not an attempt to put a pin in a chart in a definitive way.
Good examples:
Most of the Midland 0-6-0's, loco's which became the compounds and 2p etc.... these dance across many lines
in fact this can be said of some examples from the GWR, Southern, LMS/Stanier and Gresley fleet which started well before WW2 but trundled on through to the end.... not always quickly re-liveried and changed much at all in an onvious way.
the 08 which really started with the last of the LMS and carries on in some ways almost to today....
Some of the current diesels that looked like they were gone but had a phoenix like revival thanks to privatisation.....
In the end its a good start to have the era structure on the table - it'll probably evolve and its never really suit the less than ten percent of us who model specifically, but its a help and a "first step" to consistency in the fleet for most who frankly, either currently don't have a clue without some guidance or don't really care yet but may some day...
