Hi Guys,
As I am about to start laying (and wiring) track, I would be interested in peoples opinion of the best way to toggle electrofrog turnout frog polarity when switching the points.
As I understand it, the frog has to be isolated from the layout and receive a switched feed dependant on which way the turnout is set?
The methods I guess are:-
1. Use something like a Peco PL13 accessory switch to switch ploarity as the point motor is thrown
2. Use a manual toggle switch and set the polarity by hand (and not forget)
3. Use the turnout's in-built wiring to power the frog from the toe end appropriately
Are there any other options? Are any a better way than others? And more importantly, if you choose to use a manual approach and then forget to throw the switch, can you damage anything (loco, decoder, DCC unit etc.) by running a loco onto the turnout without a frog set correctly?
Excuse my naivety...just finding my feet in the wacky world of DCC wiring
