1 - 16 of 16 Posts
Hi all
I would like some advice on the best way to surface my girder bridge, OO scale, set in the 1960s. Currently it's just hardboard with a single track glued down onto it. What I'd like to know is which would be better - timber or chequerplate metal - and would the sleepers be totally hidden as in say a level crossing?
Any suggestions or examples would be very much appreciated.
Hi mike
It isn't normal for track to have sleepers (as per main line tracks) on metal bridges though there are of course exceptions.
On most metal bridges the track is supported on Wheel Timbers. These are longitudinal timbers of huge cross section and normally run the full length of the bridge. The tracks chairs are screwed down onto the top of these and metal tie bars and some wooded cross beams are used to hold the wheel timbers in place to prevent the track going wide or narrow to gauge. Some bridge have a metal decking onto which the wheel timbers are laid and bolted down to. While others (usually very small bridges) use a wooden decking. Brick built bridges normally have conventional ballasted track on them.
I'll try and locate some photos of the wheel timbers in use on BR and upload them.
From a few photos in various books I have it would seem a short metal girder bridge, across say a stream or farm track, might well have ordinary ballasted track. But larger bridges mostly appear to have the large longitudinal timbers Brian describes. You can use ordinary track by gluing it down onto your timbers then cutting away the sleepers. A better representation can be got by using PECO track and their slide-on chairs and gluing these down to the timbers.
Thanks Thunder, Brian and John for those replies.
I think I'd prefer the wooden decking. Mine isn't a long bridge - about as long as my 0-6-2T plus 1 coal wagon. [12ins or so] The Wills timber plank sheets I have should do the job nicely. Not so sure about the wheel timbers. Never heard of them til now!
I've tried google for images but I haven't found anything really useful yet.
Thanks again.
On what is known as Chain Bridge in March, Cambridgeshire and part of the planned Wisbech & March Bramley Line, there are sleepers between the rails and across the iron bridge. If you care to go to www.freewebs.com/bramleylinesupporters and then their photo album, there is a photo of this same bridge and showing sleepers across it. I know for a fact they are there because I photographed them before and after my mate, a fellow member of the Track Clearing Team, cut a tree down that was growing in between. Whatever your decision, I hope it works out for you.
You got to the St. Andrews Model Railway Exhibition then Neil.
Think we talked your visit to Scotland (was it Leven?) some months back. Sorry that we never arranged to have a chinwag. I was at the Saturday exhibition. Which day were you there, if you can remember? Were you at the Cupar Exhibition?
Hi trainman
QUOTE On what is known as Chain Bridge in March, Cambridgeshire and part of the planned Wisbech & March Bramley Line, there are sleepers between the rails and across the iron bridge. If you care to go to www.freewebs.com/bramleylinesupporters and then their photo album, there is a photo of this same bridge and showing sleepers across it
Strange this one... The Bramley site takes a while to load then when you select Bramley Line Album it tells you to click on a redirect link to Photopic. When that loads all I can view is three sheets for text. No photos! I've left it for ten or so minutes but it wont upload any photos. I can only see some small pictures in the PDF contact strip! Does anyone else have a similar problem at this site??
Bramley pictures or should be?
QUOTE (Scooter @ 16 Oct 2006, 19:43) <{POST_SNAPBACK}>You got to the St. Andrews Model Railway Exhibition then Neil.
Unfortunately I missed the Cupar one.
I went to the Sunday one at St A's. Shame we never arranged to meet but I will be back home in a couple of years so maybe we can line up something then.
It was an Ok show. Had a bit of everything. I don't get to see many Scottish layouts over here and when I do they are often disney interpretations rather than realistic.
1 - 16 of 16 Posts
