1 - 20 of 52 Posts
· No Longer Active.
Somehow BRITHO forgot to post this ;
Sat/Sun 29/30th,November 2008.
Organised by the North Kent Model Railway Group
St.Gerges School (opposite ASDA)
Westwood Road
Broadstairs
Kent
CT10 2LH
Sat 10.00 > 17.00
Sun 10.00 > 16.00
We will be there in the infamous St.Laurent & the sales stand.
A good exhibition to visit.
Look forward to seeing you there - please be sure to introduce yourselves.
So it's the same weekend this year as last? but with SL as well as the sales stand???
I'll be there, Fancy a hand with the layout or the sales stand?
QUOTE (Spud Murphy @ 23 Nov 2009, 19:30) <{POST_SNAPBACK}>a black hoodie with "Spud" on the back in reflective silver writing, and a badge on the front with "Thanet Scooterists" on it
Should be easy to spot you then!!
· No Longer Active.
Discussion Starter · #9 ·
QUOTE (Spud Murphy @ 23 Nov 2009, 19:30) <{POST_SNAPBACK}>il make life easy brian, il wear a black hoodie with "Spud" on the back in reflective silver writing, and a badge on the front with "Thanet Scooterists" on it
Just don't wear a uniform you're not entitled to wear !
Seriously - look forward to meeting you & any other MRF inmates (sorry, members).
Does that mean I cant wear my new NASA 100th Shuttle mission Jacket?
Is that the one with the built in helmet and beeping sounds?
No its the one with the built in ejector rocket, complete with pull tag!
Sounds a bit dangerous, someone might "accidentally" remove the firing pin!!
QUOTE me?
It's ok Spud it's not aimed at you. The true target is sure to respond shortly. After a while you will start to notice a pattern.....
QUOTE (dwb @ 24 Nov 2009, 22:13) <{POST_SNAPBACK}>It's ok Spud it's not aimed at you. The true target is sure to respond shortly. After a while you will start to notice a pattern.....
Do they mean me? Oh, I think they do..........
QUOTE (Brian Considine @ 29 Nov 2008, 08:05) <{POST_SNAPBACK}>Somehow BRITHO forgot to post this ;
Westwood Road
Broadstairs
Kent
CT10 2LH
Sat 10.00 > 17.00
Sun 10.00 > 16.00
So this is in no way misleading then?
Which day do you want a hand as Im available both (this might change tho!)
1 - 20 of 52 Posts
