QUOTE (Mike Button @ 25 Jul 2007, 12:31)
<{POST_SNAPBACK}>Good choice of topic Doug, I'm fairly naive when it comes to the internal workings of the loco's I run, but as I understand it capacitors are used to stop interferance with other electrical systems, such as TV's, radio's etc. I'm running a DCC layout in my shed, another passion of mine is cricket, and listening to the test match on long wave requires delicate positioning of the radio so that the interferance from the layout is kept to a minimum.
From a purely selfish viewpoint so I can listen to the cricket whilst the trains go round, I would be in favour of capacitors being fitted, but have no idea of the impact upon a DCC system so will look forward to hearing other viewpoints.
The capacitors and other suppression devices that manufacturers fit to their locos are there to make their products comply with EMC regulations.
The most effective place to locate these components (especially the capacitor) is directly on the motor terminals, or even better, inside the motor itself as Maxon do. Having them so close to the source of the interference minimises the current path and the antenna effect of the motor wires thereafter.
Using a DC controller with this arrangement has no effect on the performance of the motor, as the capacitor simply charges to the set DC voltage, and suppresses any AC noise that comes back to it from the motor. The loco will have been tested and approved for EMC on the basis of this set-up.
When we add a DCC decoder into the system, the method of controlling the motor current is radically different to that of a DC controller. For reasons of efficiency, low power dissipation, etc, all DCC decoders drive their motors using pulses of full voltage. The variability of speed is created by altering the 'on time' relative to the 'off time' of the drive pulses.
In effect, the drive has now become an AC signal too, and the capacitor will try to filter out the sharp edges of the pulses, which it sees as high frequency noise, just like the interference.
However, the circuitry needed to generate these motor drive pulses often doesn't like this kind of extra 'capacitive' loading, especially if the decoder is using a 'back-emf' control method which tries to measure the actual motor speed while the pulse is off. The apparent effect on the motor is that of poor or unpredictable running, because what the decoder tries to put out to the motor is not what actually happens.
It is often claimed that the original motor capacitors can be removed because the decoder now does this for you. However, any such suppression built into the decoder is at least a wires length away, arguably two if you count wires to both motor terminals, and these can now transmit their interference into the air, the effect of which will vary depending on wire length and the way they are laid out etc.
The only real answer to all of this aspect is for decoder designers to allow for capacitive loading on their outputs.
Then there is the 'conductive emissions' aspect, whereby the action of pulsing the motor so quickly causes the current drawn from the track to vary in sympathy, so the track itself will act as a transmitter of the pulses (mostly the odd harmonics). The only way round this one is again to build into the decoder sufficient filtering to prevent the motor current reaching back through the decoder power supply stage. However, to do this effectively would likely require some fairly enormous inductors, which are rather impractical in the sizes of decoder we expect to use.
I bet you wished you hadn't asked now!
