Can any member help on this topic
The clear/red indicator LEDs fitted to the powered/trailer bogy cars, all eight LEDs appear to light up when at standstill within an area where the power has been cut off - on the particular area being powered up by setting the point blades, the indicator LEDs are no longer illuminated.
Disconnecting the power controller unit from the rail circuit in question has no effect in the LEDs illumination being extinguished or powered on.
Through careful checking and mostly trial by error, the disconnection of the Gaugemaster electronic rail cleaner, this error is corrected. The fault has only recently occurred, with no alteration to any circuitry being undertaken or changes to the layout.
Help in tracing this error and corrected would be most appreciated. double00.
