Cleaning Locomotive Engines
1208 Views 4 Replies 3 Participants Last post by  poliss
Can anyone assist me with information on how to properly service my loco motors. I don't want to damage them, but they do need cleaning. There are bits of fluff and hair in them ( i bought them 2nd hand from a previous owner who didn't service them ).
I would appreciate it if anyone could post some information or links that might be of assistance.
Best wishes,
Hilton
1 - 5 of 5 Posts
There are some tips on this link. http://tinyurl.com/cfv6m2
Hi Hilton,
The easiest way of removing fluff and hair is with small tweezers. For a good cheap source of tweezers try the make up section at the supermarket.
Use dry kitchen paper or cotton buds with a small touch of white spirit (be careful it doesn't attack certain plastics and paint finishes), for removing crud. With excessive crud on the wheels, try using a wooden matchstick or a coffee stirrer, to flick it loose. DO NOT use the blade of a screwdriver as it will scratch the wheel tread and cause more problems later on.
Usually the only things that really need oiling are bearings and pins on metal coupling rods. Apply a small drop of oil with a fine point needle. Too much oil will attract dirt so if you have applied too much oil dab it with kitchen roll to soak it up and remove the excess. Unless you are absolutely certain it needs oiling it probably doesn't.
Check any wires for loose connections, pulls, nicks, etc. Resolder any loose connections and protect any nicks in the wire sleeving with a short length of heat shrink. You may need to replace the odd wire if it has been really badly damaged but you can usually get away with rejoining and covering with heat shrinking.
Check any wiper pickups are making good contact that they are not binding on the wheels or floating free.
Try and run you loco on a rolling road, check for any binding and if running is erratic then check for poor electrical contact.
Most of the time, removing the fluff, cleaning the wheels and checking the pickups will be all a loco needs.
Take you time, don't rush the job and don't over oil it.
HTH
Thanks guys - I have found both your tips very helpful - especially the link provided above.
The only thing I'm not certain of are the wiper pickups - what are these and where would I find them on the motor/drive axle? I have a Lima Diesel that has a motor attached to a universal joint and propshaft as well as an electric bo-bo locomotive with the motor directly fitted in the drive axle.
Thanks again for your help - it is much appreciated.
Best wishes,
Hilton
If you look underneath the 'tick' and 'stop sign' on this link you should be able to see the copper pick-ups. http://www.katousa.com/N/GG1/maint/GG1Wipe1.jpg
They will of course vary from loco to loco, but they should give you an idea of what to look for.
Closer view on this pic. http://www.katousa.com/N/GG1/maint/GG1Wipe2.jpg
1 - 5 of 5 Posts
