1 - 7 of 7 Posts
Does anyone have one of these?, the one with the brass tank body and a cleaning pad underneath.
If you do could you measure the height from the rails to the top of the filler as I want to knowif it will fit under the catenary on my swiss HOm layout. I'll be regauging the bogies to 12mm gauge if it will fit under the wires.
A small point to bear in mind Paul,
I suspect the measurement Doug has given may well be the model in the resting position.
Be aware that when operating both the filling screw and the Delivery nozzle need to be screwed out (up) so it will be a few mm higher.
duztee
1 - 7 of 7 Posts
