Maintenance goes on.
We install the railings on the platform of the rotary railcar dumper, plus some LED lighting. The first task is cutting to size all the required poles and pieces of the railings. The poles are installed into evenly spaced holes in a wooden base, and stay ready for soldering.
https://flic.kr/p/11627645223 The handrail is then soldered to the poles.
https://flic.kr/p/11628170556 Other pieces of the railing are soldered, with the help of templates and 2-side adhesive tape.
https://flic.kr/p/11627376735 The excess of solder is removed, and the piece is finished.
https://flic.kr/p/11627597603 The railing is complete and ready for installation. We also install 4 poles with LEDs. The (-) terminals of the LEDs are connected to ground (the railings), the (+) terminals are wired together with wire-wrap 30 awg diameter. The lampshades are made of millimeter paper, cut to size with cutter and ruler, folded and glued with cyanoacrylate, and painted black with conventional enamel. One drop of cyano glues the lampshade to the top of the lamp.
https://flic.kr/p/11627705454 Lighting and railing installed, lights on. The platform is illuminated. One interesting note regarding LEDs: as usual, we use "cold white" 3 mm LEDs, to simulate the light of mercury arc industrial lamps. Some weeks ago, one guy in Bologna suggested to us to grind the LED housing with 600-grit sandpaper, to better simulate the lighted housing of an industrial lamp. We did it, and it works. In place of the usual point source of light, the LED appears as a diffusely lighted lamp housing.
https://flic.kr/p/11627659473 https://flic.kr/p/11627160835 https://flic.kr/p/11627340985 Next step will be the installation of other 6 light poles at ground level below the dumper, and the stairs to the platform. A layout is never finished.
Sincerely yours and again happy New Year.
Mario & Bice
Mario & Bice
