Hi All
As many of you may know I collect Fleischmann HO
I have spent quite a bit of time on this old "T3" Loco , one of the first "old Timer loco's" Fleischmann made in HO this one dates back to 1956
as I have 2 of these , I thought I would convert 1 to DCC (excuse the Blue and yellow wires I haven't put new rear lights in yet)
It has a different motor mounting than the later 1960's Locos but I thought I would do a "Dodgy Bros" conversion of the Isolated motor Backplate to make it fit
The motor body had to be filed away at the top to fit the locating tab of the new back plate the Backplate had to be packed up underneath a little to stop it flexing when the mounting screws are tightened. The Original lights were replaced with LED's
The front lights look more O scale than HO
I have the little Lok running on the test track as I type , not as smooth as the 60's loco's but after a bit of fiddling with the backplate and running it in for 10 min each way , its running OK. A bit more CV adjusting and I will have it running slow correctly
The I will have a go at installing some rear lights
This is the BR89.7 or T3 definitely qualifies as a Toy
Regards Zmil
