QUOTE Lisa ... I am generally dissatisfied with Hornby tension lock couplers (looks, functionality and compatibility), and I am intending to do a mass overhaul of the couplers on my running stock ... based on your experience, what would you recommend?
Couplings are quite a personal thing really, as what suits one person may not suit another. At present I'm using 3 links, but am looking at changing to an auto coupling soonish, so like you I'm considering the best option, except I've used them all before so know the good and bad points of each. I think you need to look at what you want in a coupling, for me that's reliable/works well, type of magnet required, unobtrusive, easy to fit/make, low maintenance, able to be used on curves down to 18" radius.
Just to show my thought process I'll break that down a bit.
Reliable/works well
I want a coupling that couples/uncouples smoothly, this means I should be able to couple up to a wagon without it rolling away, or needing a hefty thump at speed. For uncoupling I want to be able to stop in the right place and it's uncoupled, no shuffling back and forth to uncouple. A delay action is usefull, but not essential, if it does have a delay action again I don't want to be shuffling back and forth to get it to work, ultimately simply backing a train over a magnet should be alll that is required to uncouple and set the delay.
Couplings which meet these criteria are; Alex Jackson, Lincs, B&B/DG, Dingham.
Type of magnet required
I have also taken into consideration what type of magnet is needed to operate the coupling, most couplings can be uncoupled with an ordinary bar magnet or electromagnet between the rails or under the track, others require their own special magnets sold by the manufacturer, which are costly compared to a magnet from the local supermarket/hardware/electronics store, and I don't want to be paying a fortune for magnets.
Couplings which meet these criteria are; Alex Jackson, Lincs, B&B/DG, Dingham, Spratt & Winkle.
Unobtrusive
This means one of two things, it either has to look like a prototype coupling, or be difficult to see (you don't have to see a coupling, that's why it's automatic, so you don't need to see it!). I'd also consider the ability to have a fully detailed bufferbeam to be important here, I don't want to loose details or have to carve out the bufferbeam in order to have auto-couplings.
Couplings which meet these criteria are; Alex Jackson, Lincs, Dingham. Kadee's are OK on BR and LNER coaches and some loco's (and US prototypes), but look awful on wagons and tank engines, so I don't consider them an option.
Easy to fit/make
I don't want a coupling which is too fiddly to make, likewise I don't want to have to make major modifications to my stock to fit it, and that includes removing details.
Couplings which meet these criteria are; Lincs.
low maintenance
Unless it gets damaged I don't expect to have to do anything to a coupling once it is fitted, perhaps a dab of lubricant now and then if needed but that's all.
Couplings which meet these criteria are; Lincs, Kadee, Spratt & Winkle.
Able to be used on curves down to 18" radius
My layout doesn't have curves tighter than about 2'6", but I have a circular test track of 19" radius which I expect all my stock to negotiate, I also don't want an unsightly gap when the vehicles are on straight track. Whether a vehicle can couple or uncouple on these curves isn't overly important, but is prefered.
Couplings which meet these criteria are; Lincs, Spratt & Winkle, Alex Jackson.
So looking at that the main options are Lincs or Alex Jackson, Lincs meets all the criteria but doesn't have a delay action, while Alex Jackson has a delay action but can be fiddly to make. There isn't a lot in it really so I'm still unsure.
The only other thing I might consider is using a DCC function in my loco's to uncouple, and in this case the Lincs coupling is the better option, making the coupling DCC controlled would also negate the need for a delayed action.
I'm still thinking about which of the two I'll go for though.
The only thing I haven't included in my reasoning is NEM pockets, as I always cut them off as I think they spoil the appearance of a model which usually has a quite open and "skeletal" look to its underframe.
Gary, you're welcome to add that list to the resource section of the site.
