Although not familiar with this particular loco/decoder, or what DCC system you have I would suggest that you reset the decoder to factory default & start again.
After setting the address & making sure that the loco operates correctly set CV5 max speed - if the loco is far too fast then set CV5 about half way in the range available & then "re-adjust" if required.
Then set CV's 3 & 4 (acceleration & decelleration) again about half way & then "re-adjust".
Once you have these basics set you can then adjust & fine tune the rest of the CV's.
Hope this helps.
Hope this helps.
