Art,
Dapol's factory sound fitted Class 08s use ZIMO decoders, but the aditional cost is way more than the price of the decoder and speaker used, which are both easy to fit afterwards.
Loksound V4 will not operate the lights correctly without modifying the model's wiring (not too difficult, but why bother when the ZIMO decoder is cheaper and works properly out of the box as the model was designed around its capabilities).
Digitrains have several versions of Class 08 sound projects set up especially to match the Dapol 08 characteristics (So that owners with two or more 08s can have some slight variations in sound between them). You will not be disappointed, but remember that these are only available from Digitrains. Anything advertised elsewhere will not be the same, even on the same decoders.
You will need a ZIMO MX644D decoder, which supports stay alive caps as standard.
There's bags of room for decoder, speaker and large capacitance stay alive, although in my experience with these models you will not require a stay alive unless your track is very dirty or poorly maintained.
Best regards,
Best regards,
