QUOTE (Makemineadouble @ 19 Mar 2007, 08:07)
<{POST_SNAPBACK}>No I've never done this particular loco but a few points to help you along your way.
epoxy in the speaker you select into the speaker baffle/housing you select. It makes for a much better job than the flimsy sticky gaskets you can buy
you might want to consider fitting a mini plug between loco and tender have a look at the selection at All components
All components
obviously you should make sure your selected decoder will fit in the tender with the speaker.....beware of the available hight as this can be a problem
thanx much....will do Q: if I am putting this thing in the tender can I use the plugs (2 of em) that are already connecting the Printed circuit board?
I plan to remove the pcb and then install the deoder.....other info I have read says that you need to "isolate the motor" by removing the wires on the motor from the picups r & l to the "brushes"
what the heck is a brush??? haven't found any expaination of thT TERM I am guessing this is the copper spools on any elctric motor asembly? am I close???
thanx much mk mine a dble
