QUOTE (wiggy25 @ 6 Oct 2007, 18:43)
<{POST_SNAPBACK}>I've been told you don't need to do alot of drilling.
I've converted a few using the method for the std4 at
http://groups.yahoo.com/group/DCCUK/files/...nstalls/Farish/
QUOTE What you have to be careful of is that you are only relying on the very small brush spring to transmit all of the current to the brush!
If you have a short circuit there is the possibilty that the spring could just fry, the converted brush not only have the spring but the brass brush as well!
What kind of short?
The spring is in a series circuit consisting of the decoder outputs, brush clip, spring, brush, motor armature, opposite brush, spring and clip. If you can get enough current sustained for long enough to destroy the spring then I would be far more concerned about the motor and the decoder. Any decent decoder these days is overload protected.
Andrew
