Status
Not open for further replies.
1 - 20 of 81 Posts
DT
MRF members' DCC Systems
What DCC System do you own?
Hornby Select4110.22%
Hornby Elite317.73%
Bachmann E-Z Command153.74%
Bachmann Dynamis4210.47%
Digitrax Zephyr71.75%
Digitrax Super Chief133.24%
ESU EcoS 50000256.23%
Fleischmann Twin-Center71.75%
Lenz Set-90 / Set-100348.48%
MRC / Gaugemaster Prodigy Advance266.48%
NCE Power Cab4310.72%
NCE Power House & Procab153.74%
Zimo MX110.25%
Zimo MX31ZL10.25%
ZTC 505 / 511102.49%
Roco204.99%
Arnold20.50%
Other (please indicate in the topic below)153.74%
None (or pass)5313.22%
What is your primary DCC System?
Hornby Select216.71%
Hornby Elite247.67%
Bachmann Dynamis3711.82%
Digitrax Zephyr41.28%
Digitrax Super Chief103.19%
ESU EcoS 50000247.67%
Fleischmann Twin-Center51.60%
Lenz Set-90 / Set-100319.90%
MRC / Gaugemaster Prodigy Advance237.35%
NCE Power Cab 3711.82%
NCE Power House & Procab144.47%
Zimo MX110.32%
Zimo MX31ZL00.00%
ZTC 505 / 51151.60%
Roco113.51%
Other (please indicate in the topic below)154.79%
None (or pass)5116.29%
What DCC system would you like to buy?
Hornby Select20.64%
Hornby Elite51.59%
Bachmann Dynamis72.23%
Digitrax Zephyr41.27%
Digitrax Super Chief144.46%
ESU EcoS 5000041.27%
ESU EcoS 50200 (colour)4213.38%
ESU Navigator (50300)20.64%
ESU EcoS Control Radio (50111 )72.23%
Lenz Set-90 / Set-100175.41%
MRC / Gaugemaster Prodigy Advance103.18%
NCE Power Cab299.24%
NCE Power House & Procab227.01%
Zimo MX120.64%
Zimo MX31ZL20.64%
Zimo MX3230.96%
ZTC 51141.27%
Roco41.27%
Other (please indicate in the topic below)61.91%
None (or pass)12840.76%
Premium Member
Hi Doug,
NCE Procab is missing
Premium Member
Doug,
The original monochrome ECoS is the 50000, not the 50100.
The 50100 was the wireless Mobile Control handset which could only work with a base station, it was never a standalone product. This has been replaced by the 50111 EcoSControl Radio which is a cordless handset that will only work with an ECoS or Maerklin CS1 Reloaded.
You might also want to add the ESU Navigator 50300 which is due to launch sometime this year (by the end of March, if you believe the ESU 2010 Price List).
If you want to be complete perhaps you should include the ZTC 505 the reduced functionality version of the 511 under teh existing list. That's what I started with.
NCE wireless. Unfortunately it doesn't work on this side of the world.
Premium Member
Interesting to see that the NCE power/procab seems to the favoured flavour!
Just another modeller
*** The NCE systems are called PowerCab and PowerHouse Pro. Procab is the name for the hand control only.
Tony - there are many, many modelers using NCE radio in the UK and Europe... it works fine that side of the world :).
Actually its one of those things that shows the sillyness of CE sometimes... Because the regulation sensibly focusses on the prevention of interference/nuisance where things shouldn't create it, it is actually no problem at all for an owner to use it... as it gives NO interference to anything.
However as its not CE approved (and expensive to get done) it IS a problem for a UK retailer to sell it.... because if he does he may be fined.
Premium Member
I have an interesting DCC setup, and probably not that common!
I have an ECoS as my main controller (Although it has been boxed up since may 08 due to major layout work, apart from a brief spell out to write the review for the hornby sound duchess), with the wireless mobile control add on. I then use a ZTC 505 through the sniffer port to run the goods yard on the far side of the layout. I also use MERG accessory decoders and will probably update to CBUS soon.
I then have a NCEPower cab for useas a programming device only, as I often do DCC work away from the layout room.
Rob
As mentioned, there are two NCE systems. if you are keeping them merged, then you might as well merge lots of others listed and the point of the exercise becomes a bit fuzzy.
For example, the Lenz Set 90 and Set 100 are the same system, with the only difference being the handsets, where as the NCE systems, although fully integrated, are more different than the Lenz pair.
Also the current arrangement doesn't differentiate between those who want to buy either NCE system and NCE PowerCab owners who want to upgrade to a PowerHouse Pro.
Should Roco be split too, into LokMaus and MultiMaus?
Also missing are....
Digitrax Super Empire Builder
Lenz Compact
The Veissmann Commander is also sold in the UK as well as the CT Elektronik system.
As Doug said, if it's missing let him know and he'll add it so you can then come back later and vote for it. That's what he did with the ZTC 505 for me.
I have an Uhlenbrock Intellibox. The CT Elektronik has been sold for a couple of years by both DCC Supplies and Digitrains, so there must be people out there who have one. If I were buying a new system I would certainly consider it. The Viessmann seems to me in many ways desirable.
Premium Member
QUOTE (Richard Johnson @ 24 Jan 2010, 13:37) <{POST_SNAPBACK}>*** The NCE systems are called PowerCab and PowerHouse Pro. Procab is the name for the hand control only.
Doug my terminology may have been wrong i tried to help .....
1 - 20 of 81 Posts
Status
