QUOTE i thought that if i put the loco on my normal DC system it would sit there with comms because the chip would isolate the power. but the log started to move in both directions with no problem???? is this normal.
Yes. This is normal. I believe it is possible to change a CV in the decoder so that it doesn't run on DC but this is not how they are delivered from the factory. I don't know why this facility is available but I am sure someone else (cue Richard) does and can enlighten us.
QUOTE i can't understand if the DCC system is always live and the loco has to be told to move by the decoder why when i put it on my old DC sytem the loco moves
The DCC system is always live.
The loco has to be told to move by the decoder.
Here's the vital bit of info you need...
When you put the loco on DC, the decoder gets power and the software recognises that the signal on the rails is DC not DCC. The program in the decoder then runs the loco as if it were DC. So there it is. Although there is no DCC signal, on DC the decoder decides to drive the motor anyway. Clever little beasties are n't they?
QUOTE sorry if this is simple to explain but it well confusing to me
No apology is needed. It seems to me that you have a pretty good idea of what makes DCC work. It was just bit about the "autonomous " decoder that was foxing you.
