I pinched some signage off the net a while ago...I wanted the 'new' BT ''openworld' van signage...my son was a bit particular about what he wanted for a birthday.......and the current signage was not available through the usual sources [ebay]...on a tranny van.
See a recent issue of Model Rail......they carry an ad for
decal paper
I got some a couple of years ago..
Once you have downloaded the 'image' you want..use something like photoshop to get it to the size required...plus, if you use something like 'Word' you can arrange several images to make best use of the decal sheet size? [a bit like [planning an etch??]
...then print directly onto the decal sheet as per instructions....I used an ordinary cheapo inkjet printer....an epsom C60?
[don't forget to set up the printer for the decal sheet size....mine were A5, I think...the smaller one than A4??
Although, before hand, print onto ordinary paper to check you have the sizes right??
now, types of decal sheet?
well, the 'wet' type usually use water to looses the decal film from its backing sheet....just like the old waterslide decals.
There are also teh rub-on type, like lettraset?
for larger decals I'd suggest teh waterslide transfers..they are easier to manipulate and bed-down over details.
I also recommend a decal-softening fluid...I used an old bottle of Microsol....bought back in the days when I modelled US stuff..
This will allow the decal film to 'shrink' down over any details that will lie underneath.
anyway, they worked for me..I only used one decal sheet, so have several unused one's hiding away somewhere
[I wonder if they have a shelf life??]
decal paper
