QUOTE (goedel @ 18 Apr 2008, 22:31)
<{POST_SNAPBACK}>Hello Geoff,
I've seen a DCX74 decoder in an Arnold Köf 3! There will be a way of doing it, although you may have to mill away some of the chassis block to fit in...the link Poliss gives is useful and actually shows that bracket above and around the motor being removed to make space. You just have to be prepared to make some permanent modifications!! Just don't give up!
Not all of Arnolds designs were theirs originally - they bought Lima Minitrain and other makes so not everything came from a DCC pioneer, and of course anything from Arnold dating before they embraced the digital way would likewise be un prepared. Later versions of models did have interfaces, and some models with an 8 preceeding the item number came with a decoder already installed!
Regarding the new model, yes it will have an NEM interface, and you would expect so for an UVP: 139,00 €
The details are on the Hornby Deutschland website:
http://www.hornby-deutschland.de
Navigate to Arnold and part the way down the new items list is the new Ee 3/3 which suggests it has the "NEM-Schnittstelle" if you click for details. Hope this helps!
And how are you enjoying your new layout by the way? I forgot to say it looked very good from the pictures you provided, with plenty of mainline and of course a certain famous bridge! Will you be attemping the scenery yourself?
Thanks, as you say it may well boil down to my willing ness to "adjust the body work"; €139 for the new model makes it worth my while persevering!!
The layout is currently being wired and needs reversing modules to keep the polarity sorted on the crossovers and the scissors. I will be doing the scenery and am currently mulling over how best to do the signalling
; I have a good stash of Kyodo Swiss prototype LED signals.
I liked the plan for your main station; I noticed that you are planning on hidden sidings below the main area. I was cautioned about that when designing only in as much as what access you need to the hidden sidings (depth and accessibility for the fiddly bits at the back where all the problems inevitably occur...). Mine will be hidden but slightly higher than the main area under a piece of lift off light weight scenery. As it is in my house and not going on the road I think it is a question of how "hidden" you need it to be vice ease of access. There will no doubt be many views on that! Good luck anyway.
BTW it is the East Surrey N Gauge Show at Redhill tomorrow which is generally an excellent day for those of us of the alpine N persuasion
Geoff
