I think that the prototypical double track centres scales at 45mm for OO. However, this is too close unless you are using really generous curves, say 1.2m radius or probably even larger. For this reason Peco make their points join for a crossover at nominally 50mm although I recently measured it to be nearer 52mm. Hornby and Peco settrack have something horrible - about 65mm.
You can adapt Peco points to give a closer separation. I recently reported, in another thread, that I have made mine 47mm which is OK for my 900mm minimum radius curves with my 60ft carriages. (Modern longer coaches would need a wider gap or more generous curves.)
