Difference in scale of HO and OO
1500 Views 5 Replies 5 Participants Last post by  7113
Can some one tell me what the difference is between HO and OO scale is?
I have been looking around for some supplies of architectural details and have found a company called GRANDT LINE PRODUCTS which do stuff in HO and S scale.
Thanks in advance
Dave
1 - 6 of 6 Posts
HO scale is 1:87
OO scale is 1:76
So the difference is OO is about 12% larger than HO
And S scale is 1/64th (which is rare)
*** Except when its SN3-1/2.... Its actually relatively common (ie probably larger than EM or P4 in numbers) when considered from a world-wide perspective.
Sn3-1/2 is very often used for 3'6" gauge modelling in SA, Australia and NZ to name a few.... There are many lovely layouts and some really nice gear in that scale/gauge combination - which can conveniently use 16.5mm track like OO and HO for the "track-challenged" modeler.
With HO (i.e. 3.5mm/1ft scale) buildings if used towards the back of 4mm layout you can create some "depth of field". A number of well known exhibition layouts use varing scales to buildings located towards the back of the layout.
QUOTE (Richard Johnson @ 4 Mar 2009, 11:42) <{POST_SNAPBACK}>*** Except when its SN3-1/2.... Its actually relatively common (ie probably larger than EM or P4 in numbers) when considered from a world-wide perspective.
Fair point Richard - I was referring to the UK where I have only seen one, extremely good, layout.
1 - 6 of 6 Posts
