QUOTE (harkins77 @ 7 Jul 2008, 03:47) <{POST_SNAPBACK}>Hi guys I was just wondering I have one of the dapol drs 66's and I was wondering if it is possible to be able to turn off the rear lights by just a press of a button for when I couple upto a rake of wagons so the loco looks right with it's rear lights being off.
I am using the digitrax dz125in decoder in one of the locos and also an old lenz 6 pin decoder but I cannot remember the model number.
The digitrax one is 2 function I know and can't remember what the lenz one is.
Any chance anyone knows if It can be done and if so how using a nce powercab controller please.
Kain.
*** It depends on the configuration of the lights. If you have auto reversing front and rear lights both ends, then front one end is coupled to rear the other and vice versa. In that case you cannot do what you wish without totally changing the lighting wiring as the lights will need to be on separate functions.
Neither of the decoders U have will do it - For full manual control as you want you will need a 4 Fn decoder:
One end white light to white Fn wire, other end white to yellow Fn wire - CV set to directional. Fn left on Fn 0 / light Fn as per default
one end red lights to green fn wire, ther end red to purple fn wire. CV for each set to directional and CV set to assign these wires to your preferred function.
CV51 = green, CV52 = purple for how the lights should act. You set to directional.
They are by default usually Fn 1 for green and Fn 2 for purple but if U need to change then the Decoder instructions will tell you which CV to use to set Function assignments for each wire.
Digitrax decoder manual makes it hard I'm afraid,,, personally I'd never use anything but a TCS M4 in this install - dead easy to programme with clear instructions and superb running.
DCCconcepts
Kain.
DCCconcepts
