I like the Zephyr, but I have a big issue when programming on the programming track. I can program the decoders in operation mod, but you can't read from the decoder, which I have found to be a problem. When I place the loco on the track and try to read or write to the decoder I get an open circuit error message and when it looks like it has written to the decoder it hasn't. I have had it read the decoder after many hours of playing but all the setting on the decoder were 255 which in some setting is impossible as I know the address to be 3?? I have done many things to try fix this fault here is the list:
Checked it was wired and connected right from the controller to the track.
Changed the wire from the controller to the track, tried many diffrent types and thickness of wire.
Checked it was wired and connected right from the controller to the track again.
Added a resistor (recommended by Digitrax)
Tried steel track instead of nickel.
Tried pretty much all the decoders on the market (still no joy)
Then sent it back to Digitrax. "A new board was fitted and checked and OK" but it still didn't work.
Checked it was wired and connected right from the controller to the track again for the hell of it.
The thing is, it worked OK when I first got it, for 10 months. but now it isn't. The guts of the controller have been replaced and tested at Digitrax. When I sent it of I left out the power pack, which I believe could be the fault with it. I don't want to shell out more cash to possible find out it isn't, unless I'm 85% sure it is.
Is there anything else I could try??? or anyone local that would like to give it a try??? It is upsetting as I sold many loco's (some that I had from my Childhood) to pay for this controller and can't afford to keep throwing money it to try and get it working or to find out I need to buy a new one. It is out of its guarantee and Digitrax will not extend the guarantee as it was working for them when it was sent back, which I can understand. I am open for Ideas and great full for all help and advise, I will be eternally great full to anyone that gets it working.
Martin Levin
Martin Levin
