EDIT to topic: As this is the ongoing topic on the DJH SAR GMA/M Garratt 4-8-2+2-8-4 model that I've finally started, here is a photo of a very well made model of this type.
I can only hope to get mine to resemble something as good as this.
Studying the plans for my SAR Garratt - again... and wondering how the connectivity would work out in practice. It is set up as follows with the front water tank being live on the RHS and the rear coal bunker being live on the LHS, so these two components would connect to the two terminals of the motor/s.
I'm not really keen on changing the supplied wheels and getting insulated wheels and adding pick-ups, but would the above configuration be really bad if I plan on adding a DCC decoder to the loco? I think that as long as there are no shorts, then it would work. The boiler body will be insulated from the water tank and the coal bunker.
I'll run the two chassis units around a bit and if they get stuck on any difficult part of my layout, I could perhaps add some pick-ups to the insulated wheels as long as the pick-ups are insulated from the chassis - right?
