Moving on from the topic on British tunnel portals and my Blog which has been rambling on over the past few years about baseboards and electrics... I'm now doing some serious scenery work.
I found some old portals that I had stashed away and although made by Faller and perhaps destined for a continental scene, they will work fine in my mixed British and continental layout.
So the portal was set up and a tunnel was made with a section of brick card and some more cardboard to give it some depth and it was fixed in place under the the mountain which is taking shape too.
As the tunnel was going to be fixed in place, the track had to be ballasted so I pulled out a little ballast and finished the tunnel entrance section. This is granite chip ballast and I think that my dilution on PVA was a bit weak. It doesn't seem to set. Perhaps in the cool garage it needs more time, but if it is still loose in a few days, I may have to add some more glue.
You can see below that my trains pass through the portal without a problem with a nice fit.
Next step: some plastering
