1 - 20 of 24 Posts
I intend to fit a decoder to my HO gauge DD40AX, this loco was claimed to be the largest diesel ever built and was run by Union Pacific, it pushed out 6000 HP using two separate engines.
In common with the prototype the model also has two motors each driving its own 8 wheel truck. Has anyone ever fitted a single decoder to run two motors and if so are there any special considerations regarding the amperage required?
I would like to fit a sound decoder but there is not enough room unless I cut away the part of the die cast split chassis which occupies the fuel tank space.
Brian
· Paul Hamilton aka "Lancashire Fusilier"
I haven't fitted a decoder to 2 motors yet but am looking at it for a Beyer Garratt project however electrically it is not such a good idea as the current draw from 2 motors will be greater than the capacity of the decoder probably. Better to have the two decoders and treat them like a consist in conventional DCC operations (conventional DCC - now there's a statement!!) or have 2 and give them the same address CV value so they operate together.
This is a common problem with 0 gauge diesels, like LF says the problem is the current draw, you need to measure the stall current of the model then find a decoder with a suitable current rating.
What make is the model? There could even be a decoder specifically for that loco...
Discussion Starter · #5 ·
Thanks to all for your inputs, the model is by Bachmann and no longer in production. The twin decoder solution had occured to me but I would prefer just one. Although the loco is a huge 380 mm in length, there is very little room internally due to the split chassis construction. There is a gap between the two facing flywheels of each motor which would take one larger decoder, possibly two smaller ones.
I shall check on the current draw and then find out if there is a suitable decoder. This project looks like being interesting as the motor contacts will need to be fully isolated from the chassis. I did this on another Bachmann diesel, the motor pick up insulation was relatively easy to achieve, hopefully this will be the same in principle but take twice as long.
At present both front and rear lighting is permanently on and a small internal circuit drives a flashing mars light on top, I'm not certain how this would react if I left the basic circuit in place and just powered it from 15 vac, I haven't done much with lighting and DCC yet.
Brian
I'd recomend removing whatever cicuitry is in there and just wiring all the lighting to a 4 function decoder (front headlight, rear headlight, mars light, and a spare, or maybe add some ditch lights or something), Digitrax decoders can be set to create the mars light effect, I can't speak for Lenz decoders, but I would think they can do the same.
Discussion Starter · #7 ·
Thanks Lisa,
Removing the circuit board will create more space between the top of the chassis and the plastic shell, maybe enough for a large chip. Lenz do a heavy duty chip (5 amps) but it does not support 128 step speeds. I could certainly get two small chips in the recovered space. I had the loco apart again today, I noticed that one of the contacts was on the outside of its wheel instead of inside, as the assembly comes apart easily it was quickly rectified but then I noticed that the two inner axles on that truck had stiff lateral movement, again rectified but I should not need to do this on a new product.
The good news is that the brass contacts on the motors are visible where they touch the two chassis side pieces, I reckon I could attach wires and isolate them without splitting the chassis.
Got to go now, we have a rare day here, sunshine and no wind. it's barby time.
Brian
QUOTE (Branchliner @ 5 May 2006, 06:45) <{POST_SNAPBACK}>I intend to fit a decoder to my HO gauge DD40AX, this loco was claimed to be the largest diesel ever built and was run by Union Pacific, it pushed out 6000 HP using two separate engines.
Brian
Is it the Bachmann or Athearn model
Both models had fairly high current draw motors in their time, the Athearn was especially hungry and noisy. The Bachamnn model was prone to motor failure as was most of the early Bachmann diesels. It might pay to look for a minium 1amp capacity decoder to power this brute.
Ozzie21
Discussion Starter · #9 ·
Ozzie,
As I said earlier, the loco is a Bachmann product now out of production, it is one of their Spectrum series models but in my opinion is not up to the standard of their current Spectrum range. This one runs very smoothly on DC so should be OK for conversion. As far as I can see from the armatures without removing the motors they do not appear to be skew wound, pity, all the new ones are. I have a good local supplier who specializes in DCC conversions, he will probably have a suitable decoder, I can take the loco in and check for size.
Brian
QUOTE (Branchliner @ 6 May 2006, 19:39) <{POST_SNAPBACK}>Ozzie,
Brian
Yes, I know the model. It must be 10yrs since they last made one. Those early kradar motors weren't up to much and failed pretty regular. Also the hotor shaft is pretty fragile so I wouldn't recommend pulling off the flywheels to check the motor. I can't remember how many we stuffed trying to get the flywheels off when the motor failed as the Bachmann replacement came without the flywheels. I would recommend that you replace the motors with Mashima 1836's or a large can Sagami if you can find one. NWSL used to do a flywheel and shaft kit for the Bachmann model but that was along time ago.
Ozzie21
i have the athearn DD40. the model is showing its age though. with the body too wide to fit the old open frame motors. both the bachmann and the athearn were great sellers so i think its about time they were retooled.
i agree with Ozzie that replacing the motors is the best idea. the mashimas dont draw much and have plenty of power. but its a big job.
i would fit 2 decoders and give them identical adresses but i dont know anything about how you would programme them. couls you programme them both symaltaniously?
Discussion Starter · #12 ·
Thanks Ozzie/Peter for that useful information, I have noted it down on the spares sheet for future reference. Setting up two decoders simultaneously? Thats an interesting problem, if there was a conflict of values for the same CV what would the feedback read if anything at all. One solution would be to isolate one decoder whilst setting up the other then reverse the process, every single CV would need to be identical on each decoder, you would have to pay attention to the polarity of the pick up and motor connections to avoid the trucks running in opposite directions, normally I don't bother which way round I connect the wires, if it runs the wrong way I just change the value of CV29 to correct it. I intend to start the installation next week, I shall keep you all posted, if nothing else it may help someone in the future.
I should not have bought this loco really,
it has just diverted me from the task of completing the loft layout and all that scrabbling about under the boards, another problem here, see my post on tracks etc.
Brian
QUOTE (Branchliner @ 7 May 2006, 21:58) <{POST_SNAPBACK}>Thanks Ozzie/Peter for that useful information, I have noted it down on the spares sheet for future reference. Setting up two decoders simultaneously? Thats an interesting problem, if there was a conflict of values for the same CV what would the feedback read if anything at all. One solution would be to isolate one decoder whilst setting up the other then reverse the process, every single CV would need to be identical on each decoder, you would have to pay attention to the polarity of the pick up and motor connections to avoid the trucks running in opposite directions, normally I don't bother which way round I connect the wires, if it runs the wrong way I just change the value of CV29 to correct it. I intend to start the installation next week, I shall keep you all posted, if nothing else it may help someone in the future.
Brian
Brian, I tried the twin decoder setup in a twin motor DJH NSWGR AD60 Garrett. It didn't work terribly well as one motor would stall and the other kept going which meant the stalled one had to catch up. So I went back to a single decoder driving both motors, 1612Mashima's mated to NWSL 1/8th 36:1 gearboxes. It works well but as with all kit built, all wheel pickup engines I get the odd brake shoe out of line and the damn thing shorts out. One day I'll sit down and sort it out. The NWSL motor kit for the Bachmann DD40X was really good as you ony used one motor, a Sagami with flywheels, but it was about 10hrs work to get it to fit and those NWSL cups and balls universals were a little finicky to fit.
Ozzie21
Discussion Starter · #14 ·
Getting there slowly, I bought a Zimo MX64H decoder today from Digitrains, it has a 1.8 amp continuous rating which should do the biz for the DD40X. There is sufficient space to place the chip upright at the rear end of the chassis, a spin off is that it also gets some air from below.
I have done a quick installation to check it all out and the loco runs smoothly and quietly. Nevertheless I have decided to strip the chassis completely and carry out a better quality installation, this will require a bit of surgery to get full access to the brass connectors, there are no natural connections for the left and right pick ups, it might be an idea to drill and tap two connector screws directly into the chassis halves.
The Zimo decoder has 3rd and 4th function wires but I'm not sure whether I can use these to operate the flashing beacon.
Brian
QUOTE (Branchliner @ 9 May 2006, 06:06) <{POST_SNAPBACK}>Getting there slowly, I bought a Zimo MX64H decoder today from Digitrains, it has a 1.8 amp continuous rating which should do the biz for the DD40X. There is sufficient space to place the chip upright at the rear end of the chassis, a spin off is that it also gets some air from below.
Brian
Watch those little plastic spacers when you split the chassis as they have a habit of hanging up and falling off when you least expect it. A mate did exactly what you are doing in that he drilled and tapped the chassis to mount the pickup wires. The Zimo should have a selection of lighting CV's to cover the flashing beacon. The preserved example is now fitted with type 2 ditch lights.
Ozzie21
Discussion Starter · #18 ·
OK so where are we now? It appears that twin decoders are not the answer to twin motor locos. A single decoder has to be able to handle the current draw. Due to variations in the motors they can still try to run at different speeds, depending how close the speed match is will result in a successfull or otherwise conversion. This is similar to the problem of multi headed consists, if one loco is significantly slower than another is it an asset or impedance to the overall pulling power? ie, will it tend to cause a drag on the stronger element of the consist and completely negate any expected advantage.
Back to my DD40X, eventually I had to completely dismantle the loco and cut away the flanges which make contact with the motor brass strips (do you think my warranty is now down the swanee
) I did not have a suitable thread tap so just drilled holes and used 2.5mm brass screws and nuts to pick up the power.
Current situation, the loco works but occasionally shorts out on the electrofrog points, I suspect the wheel sets are of poor standard but generally not a bad installation.
My loco is undecorated, does anyone know of a supplier of Union Pacific decals in HO?
Brian
yep microscale are good. they also sell microsol decal fluid which is very hard to come buy over this side of the pond. if you get the decals imported it mnight be a good idea to get a bottle of microsol and decalset(is that the name of the second one? mine ran out ages ago) at the same time.
1 - 20 of 24 Posts
