QUOTE (Doug @ 5 Mar 2008, 07:25)
<{POST_SNAPBACK}>IR signals are coded by brand and model.
Under your TV, you may have a VCR (remember them), a DVD player, an amp a media center etc. I have about 4 remote controllers on my lounge coffee table. They are all IR controlled, but they don't interfere with each other.
Have you tried using two, or more, different remotes
at the same time? You may well find they interfere.
QUOTE The Dynamis, if used within range of a TV, shouldn't interfere with the control signals and visa-versa.
I wouldn't be so sure. If someone tries to change channels at the same time the Dynamis is transmitting then there will be some interaction. The outcome will probably be that nothing happens until one stops transmitting.
What is unlikely is that operating the Dynamis will change TV channels or using the TV remote will affect the layout.
Andrew Crosland
