East Lancashire Railway in N-Gauge.
2859 Views 44 Replies 5 Participants Last post by  Chris Hallows
This is my new layout, I started the build in June 2022. I have made the layout modular like my last layout but this time it is easy to pull apart and I do not need to crawl round the back to access the fiddle yard. I am using the fiddle yard from my old layout which is 18" deep, the new section is 20" deep from the fiddle yard, apart from a extension I have added on the right front so I can have a small goods yard. The two ends are "L" shaped boards with two boards joining up which I have made from ply rather than the conventional 2x1, the track bed is 9mm ply. These two boards are intentionally curved inwards, the layout is a folded over figure eight with two levels like my old layout.
The idea of the layout is scenes from the book East Lancashire Lines, Bury to Heywood by J wells and pics by EF Bentley. I also have another book on Railways around Bury by J Wells which is also a source of information. So the layout is fictional but with scenes from around this area. I just completed wiring the scenic layout and have tested my Z21 for the first time. I have put the wires in ready for when I get round to laying track for the goods yard.
Picture frame Wood Track Engineering Railway
Table Picture frame Wood Flooring Floor
Table Wood Electrical wiring Engineering Office equipment
Shelving Wood Gas Machine Automotive design
  • Like
Reactions: 5
41 - 45 of 45 Posts
Thanks Norm, I have finished making the simpler inner frames and have painted them with Halfords grey primer. I have now realised it will be easier to paint them before fitting them to the span units. Not sure what colour I will use yet, but I will paint them all with my airbrush. I can then make them up and fit them under the track bed, I can then start work on the stonework at the ends and the brick pillars.
Chris H.
Well I have made the units up with the painted frames, like I post previously I have fitted three inner frames, not four as on the real bridge. To be honest it would have looked a little cramped with four anyway. I painted inside the pillars so no wood will be showing. I have now fitted two frame units and also fitted the rears has well, waiting for the glue to dry on the second rear. I have also made a start on the left end stone work, I have made a piece with stone that goes between the girder frames.
Green Wood Automotive tire Automotive exterior Bumper
Motor vehicle Wood Shipping box Urban design Railway
  • Like
Reactions: 2
More progress with the viaduct, I have now got three spans fitted. I have added styrene strip H girder to the top of the frames, the plan is to fit the railings on the top of it. It needed painting so I masked the track and the girder frames and painted the top girder with Badger Stynylrez Primer, it comes ready thinned but my airbrush nozzles are too small so I thinned it slightly with distilled water. Once dry I removed the masking off the frames and painted the girder with the Tamiya Dark Iron acrylic, pretty happy with the result.
Green Urban design Wood Line Rolling stock
Green Motor vehicle Wood Mode of transport Urban design
Urban design Building Wood Landscape City
  • Like
  • Love
Reactions: 3
I have done more work on the viaduct, brick center pillars, and made a start on the left end stone wall. I bought some railings last year but unfortunately did not buy long enough lengths for this viaduct. Two suppliers are both out of stock so I only have enough to do one side but at least I can now build the end walls.
Train Building Rolling stock Transport hub Urban design
  • Like
Reactions: 3
I have not posted for a while, here is a update on the layout. I have done more work on the viaduct, walls made out of stone styrene sheet, actually oo gauge, the n-gauge stuff looked too small compared to the real viaduct. I have made a start on the brick pillars in the center too, and laid some water based varnish down for the river. I bought some railings a while ago and they are ideal for this viaduct, I have fitted some to the front. Unfortunately they were out of stock with suppliers, but I have had a message today they are back in so I should get them soon then I can complete the rear side of the viaduct. I have also fitted another two Dapol signals, one is a distant signal so I have made a start on wiring for them plus a new control box for them too. On the right side of the layout at the front I am going to fit a signal box, made from a Ratio 236 kit but modified to look like the old Bury North signal box. I have only started on that today, I have changed the roof and swapped which end the ladders go to the right side. For safety I have the lower door on the end not the front like the real box, it should look the part.
Chris H.
Water resources Water Wood Brickwork Landscape
Audio equipment Engineering Machine Wood Cutting mat
  • Like
Reactions: 3
41 - 45 of 45 Posts
