David Good Evening Thank you for your reply. I have been indisposed today( In Hospital ) Procedure Cancelled after 6hours of waiting since 07:00 am I will set it up tomorrow and see if I can make sense of it. I will keep you up to date. BabsI have the mono ECoS which has a fixed output power supply so what follows is a guess - Is there a readout of the track voltage on one of the information tabs on the ECoS 2?
To measure the volts at the track I believe you can do it with a multimeter set to AC volts.
Alternatively various DCC accessory suppliers make DCC voltage meters. I have a RRampMeter which I got years ago long before DCC concepts brought out their Alpha DCC meter.
