QUOTE (John @ 30 Aug 2008, 16:13)
<{POST_SNAPBACK}>Dear Puzzler,
Connection is via Ethernet Cable, see the documentation. No special s/w is requried if you only want to perform the functions described on p. 29, p. 30 and p.31 of the manual. These are updating the firmware on your ECos, or backing up and restoring your configuration data (including the defintions of locos and accessories).
If you want more advanced functions, like full control of your layout via s/w on your Laptop, then you will need additional s/w, like R&RCo or JMRI (Panelpro and DecoderPro), and additional components on your layout for location feedback. These packages only work if someone has written an interface program (communication protocol) for the ECos. You would have to check with the s/w vendor to find out which ones work with the ECos. Looking at the websites, it seems that R&RCo works fine with the Ecos (see
here). I don't see the ECos listed on the JMRI site (see
here), but there may be a way, as it is actively being discussed on the
JMRI Yahoo Group right now. I am sure someone will come up with a solution in the near future.
Thanks John you have been very helpful, I'll take a look at R&RCo
Paul..
