QUOTE (rob1n @ 25 Oct 2008, 02:04)
<{POST_SNAPBACK}>Question
Am I entering the commands in the right order?
In the enter new accessories menu do I need to enter anything in to the ACC. Box
Thanks Robin
It sounds correct although this bit I think is for Switchpilot decoders. LDT and Roco point decoders are prgrammed via the button on them. The value which you input is triggered by you switching the appropriate number point on the ECoS. To do your point as number one. You would set up all the detail of point one on ECoS; then go into programming mode and then switch point one on the ECoS.
QUOTE 3. From the main menu
Open setup 1 Decoder programming
Select P.O.M
Select Accessory
Bottom of the screen in the Address box enter 1
Address shows 1 [1-4]
Press Enter
I am assuming you have a power source to the decoder as you say it is moving when in programming mode. Are you using power from the track or a separate power source?
In the ACC box you should tick magnetic article.
You could also try setting a slightly longer duration for the point motor.
Have a read of
this and see if there is anything here which is of help.
