QUOTE (80class @ 30 Jan 2008, 07:18)
<{POST_SNAPBACK}>Thanks for the help, but sadly the EcoS is still cutting out first.
I has set CVs 49, 50 and 51 all to zero and checked them. I have also tried the current shunts in all the different locations with no joy. Perhaps they are not compatible!
I notice that from page 28 that the booster cut out time is for EXTERNAL boosters, I wonder dose that mean you can't adjust the internal boosters cut out time?
Thanks,
Rob
**Yes, but then the manual says on page 28
"These devices are displayed as if they are external to ECOS but The devices "ECoSniffer" "s88-Bus Control" and "External Booster Control" will always be displayed even if there are no external devices connected. These three devices are integrated into ECoS but are displayed as if they were external."
Go figure......
OK then, Back to the drawing board Rob:
The problem is real - this has hapenned with a couple of newer control systems where they have been configured with overly sensitive protection. It has affected previously OK products like auto reversers and overload protection devices of many brands.
For example Hornby Elite, Bachmann and ECOS all have the same sort of problems relating to some devices - and its hard to allocate responsibility either way really.... Usually this is changed by the Controller Mfg company eventually..... but it appears to have not been implemented yet with ECOS.
OK....
There is an adjustment for the current threshold in the ECOS on page 27 section 18 discusses it - (attached here) try setting it to maximum so the EB-3 reaches limit first.... ALSO - as a trial, reset the external booster time within ECOS to zero (as per previous page I attached).
If there is still no joy, then there is a workaround / Possible option:
I recommend this ONLY Providing that all parts of the layout are EB-3 protected. You can current limit the ECOS externally by connecting a reactive load that won't affect normal running but WILL stop it shutting down totally unless the short is long term and total. (ECOS will still always be safe if )
In series with one of the leads between EB-3 and ECOS, place low voltage car tail-light or similar light bulbs of a size that will give a load slightly higher than that at which you set the EB-3's.
Because this load is a reactive buffer it will prevent the instant recognition of a short by the ECOS, so the EB-3's will react faster.
a quick ohms law calc assuming ECOS track voltage is about 16 & we want a load capable of up to between 4 and just below 5 amps to be buffered says that we want a total load of bulbs equivalent to 65~75 watts max. a couple of tail-light bulbs in series may give this OK.
I Hope we are getting closer....
