Recently received a new Hornby Class 31 TTS. Initial set up with ECos 50210 controller and test proved OK. Then something strange was noted. Loco would only respond when placed on
the track in one particular direction. Turning the Loco in the opposite direction resulted in no response. Returning loco back to track in initial direction and control was
regained. Took loco around a reverse loop and although loco continued after exiting loop there was no speed or direction control. What is going on there?
Resetting the decoder made no difference. I then checked the loco on a small test track with an old Hornby Elite and it worked fine in both facing directions. Other TTS locos appeared to
work fine on the layout when under the control of the ECos, why not this one? Is this an ECos problem or a TTS problem? The track voltage is AC, why would the facing direction of the
loco make any difference?
Subsequently I also noted that the Loco was only recognised on the programming track in one particular direction. I must have been just lucky that the initial set up had been with the
loco set up on the programming track in the right direction, a 50% chance I guess
Please Help
Please Help
